01-03-2024 05:29 PM - last edited on 01-04-2024 08:37 AM by Danny
Greetings. I dropped my EOS 70D on the pavement. The battery door broke off and the camera won't tun on. The Canon web site indicates that repair on this model is no longer available. Does anyone have any suggestions before I take it to the local camera repair shop? Many sincere thanks for any help you can provide.
01-03-2024 06:15 PM
Did the battery door break off (the hinges where it attaches to the body), or did it just COME off? It is removable for when you use a battery grip. Can you hold it in place while you turn on the camera? The camera will not turn on unless the cover is fully seated.
Either the cover broke or the hinges on the body broke. If you can't tell which, a camera repair shop can at least tell you. A broken cover can be easily replaced. Broken hinges on the body is a whole lot worse.
If you can't see what broke
