11-29-2023 11:33 AM
Hello, I bought Sigma 18-250mm f/3.5-6.3 DC Macro OS HSM, on lensora site it said that the Sigma lens and Canon EOS 1300D are compatible, but the lens doesn't fit. Anyone knows what to do?
11-29-2023 11:53 AM
Did you specifically purchase the EF mount version (part number 00-85126-88354-6)? If not, you'd need to return it and exchange.
11-30-2023 05:32 AM
Unfortunately, you've told us everything about that lens except the one thing that matters, which is the lens mount. That lens comes in a variety of mounts, but only the EF version will fit your camera. As Ricky said, if your lens isn't EF, you'll need to exchange it.
If you want to know more about lens mounts and compatibility, I wrote an article about it: https://moonblink.info/MudLake/gear/lenses
11-30-2023 04:52 PM
The lens is compatible if it is the EF-mount version. Is it?
This is odd because i just looked to see who/what Lensora is. Doesn't appear to be a place where you can BUY anything....just an information site. Who exactly did you buy your lens from?
11-29-2023 11:53 AM
11-30-2023 05:32 AM
11-30-2023 04:52 PM
11-30-2023 04:54 PM
I didn't buy it from Lensora, I bought it from another person.
The problem was the fact, that in the auction it was said that the mount is EF-S, but it was a lie and it has been an completely other mount.
11-30-2023 05:12 PM
If you bought it on eBay, open up a return case. Even if the listing said "No Returns", eBay will put it through if it was misrepresented by the seller.
11-30-2023 05:16 PM
I already resold it.
Thanks for your and also AtticusLake's and Ricky's help.
