04-30-2024 07:07 PM
Just want to confirm, that these are busted pixel lines.
when picture is sent to phone, lines arent visible.
04-30-2024 09:13 PM
The camera can be set to crop the image for you. I would double check your settings. I would also reset the camera back to factory default including custom functions. The camera must be set to the creative zone on the top mode dial (M, Av, TV & P) modes.
04-30-2024 08:24 PM
It appears that cropping has been set in the camera. What camera are you using it appears you're using a mount adapter. Is this the only lens that has that problem. The EF 75-300mm lens is very poor optically. It also uses a very slow AF motor called Micro Motor. This AF motor was first released in 1993.
04-30-2024 08:40 PM
Eos r100.
Yes only lens that have this issue. No cropping was done. Simply picture taken and then picture review.
04-30-2024 08:42 PM
Yes i have an ef eos canon adapter connected.
04-30-2024 09:13 PM
04-30-2024 09:15 PM
I try that tomorrow thanks
04-30-2024 09:21 PM
What other lenses do you have. The images with that lens shouldn't be cropped at all. When using EF-S or RF-S lenses on a Full Frame EOS R series camera. The image is cropped to the APS-C image circle to prevent vignetting. The EOS R100 is an APS-C camera therefore this shouldn't be happening.
05-03-2024 10:58 AM
Resetting the camera basic functions removed the cropping lines. As far as how i put that setting on there, not sure. I understand this camera and lens isnt the best of the best but so far im pleased with the results (cost+quality). Thanks again.
