75-300mm non USM lines in picture preview
Geneuwin07
Just want to confirm, that these are busted pixel lines.
     when picture is sent to phone, lines arent visible.
  • Worth keeping?
  • Is this normal?
  • Bad pixels?
  • Camera is new out of the box
The camera can be set to crop the image for you. I would double check your settings. I would also reset the camera back to factory default including custom functions. The camera must be set to the creative zone on the top mode dial (M, Av, TV & P) modes.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L USM, EF 24-70mm F/2.8L USM, EF 70-200mm F/2.8L IS III USM, EF 50mm F/1.8 STM, EF 85mm F/1.8 USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D
7 REPLIES 7
deebatman316
It appears that cropping has been set in the camera. What camera are you using it appears you're using a mount adapter. Is this the only lens that has that problem. The EF 75-300mm lens is very poor optically. It also uses a very slow AF motor called Micro Motor. This AF motor was first released in 1993.
-Demetrius
Eos r100.
Yes only lens that have this issue.  No cropping was done.  Simply picture taken and then picture review.
Yes i  have an ef eos canon adapter connected.
-Demetrius
I try that tomorrow thanks
What other lenses do you have. The images with that lens shouldn't be cropped at all. When using EF-S or RF-S lenses on a Full Frame EOS R series camera. The image is cropped to the APS-C image circle to prevent vignetting. The EOS R100 is an APS-C camera therefore this shouldn't be happening.
-Demetrius
Resetting the camera basic functions removed the cropping lines. As far as how i put that setting on there, not sure. I understand this camera and lens isnt the best of the best but so far im pleased with the results (cost+quality). Thanks again.
