10-01-2015 12:00 PM
I have tried searching the error in the forum and after the support team asks what operating system they are using, the user answers but there is no reply or answer from support after. Why suddenly does my Canon MX470 series printer not work when last week I had zero problems? I am running Windows 7 and the error message says "The printer is offline. Check that the printer is connected and the printer power is on". I've done those things and now I'd like a clear concise answer to help me use my printer please.
10-02-2015 02:29 AM
If the printer is connected via wifi ...
Assuming that the printer's connection to the router is good (which can be verified by printing a LAN details page), there are a few possibilities. I'll order them by likelyhood, in my own opinion (though I strongly recommend printing a LAN details page to confirm a good signal strength and valid IP address)
1. You could have Windows set to use the printer offline (R-click on the printer in Devices and Printers => See what's printing => Click on "Printer" where "File" would normally be => Uncheck "Use Printer Offline")
2. You have the printer set to the wrong port (R-click on the printer in Devices and Printers => Printer Properties => Ports tab => The port should start with the letters "CNBJ"
If the printer is connected via a USB cable ...
2. The computer hardware might not be recognizing the printer (Go to device manager and check to see if the printer is listed under "Imaging Devices"
Let us know how that works and we can go from there.
06-18-2018 12:14 PM
08-07-2017 08:00 PM
08-07-2017 08:02 PM
08-07-2017 08:03 PM
Hi Sfb101966!
Thanks for posting in the Canon Forums!
The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback.
If are you in the United States and this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team. If you are in a time crunch, there is an option to email our technical support team. Emails have an 8 hour turnaround time.
If you live outside the United States, please click here and select your country or region for your support needs.
08-07-2017 08:03 PM
