Desktop Inkjet Printers
My printer/ scanner won't scan
I have a Canon Pixma printer/scanner. I'm trying to scan something and an error message comes out. It keeps saying "can not communite with scanner for these reasons: USB cable is disconnected. Scanner is turned off".  The USB cable is connected and t...
sadharlow by Contributor
  • 16395 Views
  • 13 replies
  • 1 likes
Resolved! Change Selphy 1300 default "paper type" for printing?
The Selphy CP1300's Windows driver circa 2020 defaults to some irrelevant settings for their KP-108IN (4x6 "postcard") supply pack. Besides needing to select "Japanese Postcard" when you want to print a simple 4x6 photo, you must manually change a de...
twalp by Apprentice
  • 19001 Views
  • 9 replies
Printer will not print AOL emails
I have a MG7720 printer on my Windows 10 desktop that will not print AOL emails. The printer works fine and will print any other documents and photos on my computer. When I attempt to print an email it goes to the preview page and the preview never l...
tae111 by Contributor
  • 1341 Views
PIXMA MG3620
Help before I lose the one brain cell that I have left after trying to fix this on my own! Till now, my PIXMA MG3620 has worked flawlessly. It was fine the last time I used it, then a couple of weeks later I had a document to print and the paper jamm...
Toadywot by Apprentice
  • 636 Views
  • 0 replies
PIXMA TR7520 Error Code 6004
Are there any reliable home printers in this world?I have had absolutely the most frustrating time with printers over the last several years. I have been through numerous printers and every single one ends up with issues that are not able to be resol...
get updates for removed printer
I run Windows 10 HOME 64bit.I had an Canon MP272 printer, but since I no longer used it, I removed (disconnected) it from the computer.Also removed Canon software. When I check for updates in Windows (Settings -> Check for updates -> Additional updat...
mgroen by Apprentice
  • 400 Views
  • 0 replies
TR7520 will not print in draft mode on Mac
I bought a tr7520 so I didn't have to buy a multi clour ink cartridge when I am uning mosting one colour. Years ago I pixma printer that had the same multi cartridge feature and never had an issue with it. This new one will not let me select draft mo...
Canon TS3322
I have a Canon TS3322 printer and a fairly new MacBook Pro. My printer and laptop are in two separate rooms, so I need to be able to print using WiFi. I can't figure out how to do this. I can only print if I bring my laptop into the room with the pri...
Pixma MX432 - Always has problems grabbing paper
Hi All, I bought this thing about 2 years ago, ran out of ink about 18 months ago, and have not replaced the ink because this problem was so bad. Do others face the same issue? Is there a solution? I would say about 75% of the time it either would cl...
jmadero by Apprentice
  • 20020 Views
  • 7 replies
