10-31-2021 03:42 PM - last edited on 09-06-2022 09:29 AM by Danny
TR4520
I'm trying to scan to 8-1/2x11 paper, which I have loaded into the cassette. The BLOW-BY-BLOW below is rather long-winded, so let me summarize:
* I can't figure out how to clear the error 2110 "The size/type of loaded paper is different from the print settings"
* It's important that I send a copy of the document to a third party; I need to retain the original so I can't send it.
* A pdf created by the Canon scan-to-pdf utility is able to print it on the same printer that is unable to scan it.
THE BLOW-BY-BLOW
SEE END OF POST FOR IMAGES
printer error 2110
* Display says "copy/100% letter
* Cassette has 8-12x11
* Press black scan
* Printer displays
"The size/type of loaded paper is different from the print settings" 2110. Underneath [OK]Select Option.I guess that means to press OK?
*Press OK
Now is says "Select Option", underneath that "replace the paper"
I already have 8-1/2x11 in the cassettte but I pull out the tray and shove it back in. I see that the Stop LED is lit. I don't know when it appeared or what I am supposed to do about it.
*So I press stop.
Display says "wait a minute", so I do.
tick-tock tick-tock
* display says "copy/100% letter"
Hmmm. Deja Vu all over again?
* Power OFF/ON
Haven't we been here before?
* power OFF
unplug.
wait a couple minutes.
plug in.
power ON
press black scan.
RECURRING DISPLAY SHOWING 100% LETTER
ERROR MESSAGE DISPLAY
TIA for your help.
pwrichcreek
11-01-2021 05:51 PM
I contacted an "expert" via canon support chat. He provided a Knowledge Base article that essentially recommended the steps that I had already taken as reported here. I was about to respond back to the expert to tell him that the KB article didn't resolve the issue, when I decided to recreate the scenario just to be certain whether I had indeed done the steps from the KB article and--SURPRISE, IT PRINTED. No 2110.
I specuating the when I had repeated the steps to document them here, I felt I didn't need to see whether they resolved the issue. Apparently they did.
For the record here's a link to the KB article.
https://support.usa.canon.com/kb/index?page=content&id=ART162469
11-01-2021 05:51 PM
09-05-2022 04:38 PM
Delete the printer from your settings and then re-install it.
that will clear the error 2110
09-19-2022 12:04 AM
just delete the Canon printer with the error and then re-install it back. Case solved.
