02-04-2023 09:21 AM - last edited on 02-04-2023 09:29 AM by Danny
I love this printer and use the scanner feature quite often. Just upgraded to new computer. reloaded printer software from internet. Printing is fine. but nothing with scanner. Cannon my garden the scanner cannot be highlighted.
[Personal contact info removed per forum guidelines.]
Please help
02-04-2023 09:29 AM
Hi, moiracleary!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-04-2023 10:18 AM
I have windows 10
02-04-2023 12:58 PM
Any suggestions?
02-08-2023 08:55 AM
Hi moiracleary,
Please follow these steps:
1. On your computer, please click the Windows button in the lower left corner of your screen or press the Windows key on your keyboard.
2. In the menu that appears, please click on the Canon Utilities folder.
3. In that folder, please click on the IJ Scan Utility to open that program.
4. Click the PHOTO button on the IJ Scan Utility.
Are you able to scan?
If not, do you get an error?
If you get an error, what is the error code that appears at the bottom of the error message box?
Are you using your PIXMA MX922 wirelessly?
or with a USB cable?
02-11-2023 08:58 PM
I use a usb to connect. Windows 10. When I click on Cannon Utilities - there is no IJ Scan Utility to open
Can you just send the link to correct
02-14-2023 10:22 AM
I am having the same issue and there is no IJ scan utility to access as you described in your directions. HELP
02-14-2023 10:23 AM
my printer is a MX920 and have recently upgraded to window 10 and now cannot scan with this printer
02-14-2023 03:52 PM
I did find a solution but not as easy. Go to settings, go to printer, go to manage printer. Tell it to scan
02-20-2023 01:31 PM
IJ Scan Utility should install with the MX920 series MP Drivers Ver.1.01. This file can be found on HERE on the Canon website.
