09-13-2023 10:43 AM - last edited on 09-13-2023 10:52 AM by Danny
I just installed new printer cartridges for my printer and I'm getting an error (168A-Install the cartridges properly)
I took the cartridges back out and re-installed but I keep getting the same error message. How can I get this fixed?
Thank you,
09-18-2023 02:19 PM
I recommend performing a reset of the printer. While the printer is on, unplug the power cord from the printer. While the power is off, press the power button 5 times. After 60 seconds plug the power cord back in and power on the printer.
If that does not work, hold down the stop button on the printer for 5 seconds and then release it.
If the ink is still not detected, please take a picture of the ink cartridge and attach it to your reply.
09-22-2023 10:55 AM
Good morning.
That didn't work. Anything else I can try?
Here is a picture of the ink cartridges
09-22-2023 01:04 PM - last edited on 05-08-2024 01:44 PM by Danny
While third party inks can be used in Canon printers, they are not recommended because they are made by a third party and not tested by Canon.
At this time, I would have to suggest trying Canon cartridges to resolve the error on the printer.
03-14-2024 11:36 AM
Hello, I have the same issue and nothing helps so far. The cartrige was purchased at Staples. It worked but the quality of print was too bad, so I wanted to re-install it and after I put it back it shows the 168A error ever since. Attached is the picture of the cartrige.
05-08-2024 01:43 PM - edited 05-08-2024 01:43 PM
Based on your description, there may be a issue with the cartridge. I recommend reaching out to Canon support for further assistance.
You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
