02-25-2024 01:05 PM
02-25-2024 04:09 PM - edited 02-25-2024 04:10 PM
I see you've recently joined the community. When possible, please provide the following. Computer OS (version and build) you are using the printer with. How the printer is connected and to what? (Router, Wireless network, USB). Have you received an error messages? Also, can you tell us any troubleshooting steps you've performed, and provide any additional observations you feel might be helpful for us to understand your issue(s) better.
~CarePaks Are Worth It
02-26-2024 10:11 AM
Sorry, For some reason, I was limited to posting any more than the brief sentence I did. I don't know why. I'm on a Dell laptop with Windows 11, Pixma MX 492 printer. Xfinity Wireless. No error messages.
After much clicking and shut down, my printing ability is back. However, my scan feature is not. I don't even know where to start to fix that. I'm not hugely technical, so I hope there's a simple solution. Thanks much.
03-13-2024 01:42 PM
When you try to scan from IJ Scan Utility is the printer listed as MX490 series or MX490 series network? Also, what error message appears when you try to scan?
03-13-2024 04:08 PM
When I press the Scan button it reads Scan Mode (WIFI) but when I press OK it defaults to Local USB and I can't get it to do anything else. Hope this helps. Thanks.
04-23-2024 01:55 PM
It sounds like you are pressing the scan button on the printer. As a test, try scanning from IJ Scan Utility. It should have installed with the Canon printer driver and can be found in the Canon Utilities folder on your computer.
When you open IJ Scan Utility select make sure the printer is listed as MX490 series network and the press the auto or document option to scan. Then let us know if the printer can scan or if a error message appears.
