09-29-2023 08:37 PM
Since I first set up my Pixma Printer, it's always printed with printer lines. I've never really worried about it till now, but as an artist I'm wanting to use it for some professional projects and I cannot have printer lines showing up. I print with primarily regular copy paper, but also photo paper and printable vinyl. I have run the clean and deep clean feature many times. If I need a new part to make it not print these lines, then I'll do it, if someone can just tell me what's causing the issue and how I can fix it. I'd really appreciate it!
10-03-2023 12:28 PM
If you have run nozzle cleanings but the lines remain, I recommend you reach out to Canon support. You well need to register your printer, please click HERE to log in and access your support options.
We look forward to hearing from you.
