12-18-2015 09:27 AM
12-20-2015 08:11 PM
Hello wcndave,
I believe that the method to cut out the feed from the DM-100 is to disconnect it if you wished to use an external microphone.
12-21-2015 02:02 AM
OK, Bit of a shame.
You can switch and mix between internal and external normally, however when you replace internal with "smart" shoe mic, you can't anymore.
Can't see why technically not.
It means doing frequent rapid changes of a rather delicate device, which will get shoved into jacket pockets and so on...
Firmware update?
