New Speedlite EL-5 Compatibility with EOS R5 and EOS R5 C
JFoss
I am surprised that the compatability for the R5 and R5C is not listed.  Can Canon officially confirm it will be supported when released so that I can pre-order??
Thanks!
2 ACCEPTED SOLUTIONS
I concur with Ricky.  The shoe on our R5 C's have the updated shoe.  Same as the R3.  I would not hesitate to pre-order.
Danfaz
Enthusiast
It's only compatible with newer cameras (R7,R10,R3,R6II) with multi-function hotshoe.
Per the product page: ImportantBecause of the transition to Canon’s Multi-function accessory shoe, please be aware that Speedlite EL-5 cannot be mounted or used on Canon cameras with other accessory shoe designs.
Also in the tech specs: Compatible Cameras EOS cameras equipped with a Multi-purpose Shoe
26 REPLIES 26
rs-eos
Where do you see that? The product page mentions:
  • This flash gets even more powerful when used with an EOS R-series camera. Assign flash functions to the control ring, utilize quick flash group control*, and set up multi-flash shooting.
I do see the following note, but the list of mentioned cameras would not imply the full list of compatible cameras (just a subset used as an example):
"Gold-plated terminals in the shoe improve connection quality, and the installation status is checked before starting communications, to ensure reliable connection to cameras such as the Canon EOS R3, R7, R10, and R6 Mark Instant Interactive."
I don't yet see a manual for the new flash, or a part of the web site that enumerates all compatible cameras.   I image though that if the camera has the more modern hot shoe, it should be ok.
Ricky
Danfaz
Enthusiast
From the EL-5's web page.
Compatible Cameras  > EOS cameras equipped with a Multi-purpose Shoe
From the R5 C's web page.
Compatible E-TTL Speedlites   > Canon EX- and EL-series Speedlites
Multi function / Multi purpose...  check, check 👍
The Canon El-1 and EL-100 use the older hot shoe design not the newer multi purpose shoe. I believe the manual for the R5C mentions those speedlites.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
EOS 40D & 5D Mark IV
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 85mm F/1.8 USM
I see this too.  It’s just weird they did not call out compatability like they did for: R7,R10,R3,R6II).  I am thinking it will need a firmware update to communicate correctly so while we all know the r5c has the newer multifunction shoe;  why didn’t they say it’s compatible in all their pre-release??
The r5c has the newer hot shoe.  Why isn’t it listed?
It’s weird they only call out R7,R10,R3,R6II. I am thinking we will need a firmware update though…
It may not necessarily be compatible. Some EOS-M series cameras have a multipurpose hot shoe that allow optional use of an EVF. I don't think any of these cameras are compatible either.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM & EF 70-200mm F/2.8L IS III USM
-Demetrius
