01-21-2022 12:29 PM
I have a PIXMA TS9020 printer. I have this error during scanning ''Printer is in use or an error has occurred. Check status. Scanner driver will be closed. Code: 2, 140, 3.
01-24-2022 01:05 PM
Hi comfycj,
On the display of your PIXMA TS9020, does an error appear?
What version of Windows are you using? If using a Mac, what version of OSX is installed?
Are you using your PIXMA TS9020 wirelessly?
Or with a USB cable?
01-24-2022 01:05 PM
Hi comfycj,
01-24-2022 08:45 PM
Hi Patrick,
See the response highlighted in red below.
On the display of your PIXMA TS9020, does an error appear? No
What version of Windows are you using? Window 10 Home, Version 21H1
If using a Mac, what version of OSX is installed? NA
Are you using your PIXMA TS9020 wirelessly? Yes
Or with a USB cable? NA
