07-23-2022 03:53 PM
I have been using the Imageprograf Pro-300 for over a year with Lightroom and have had no problems. Now any time I try to print it just says Error printing - no code or further explanation. I have been fiddling with this for a week with no luck.
01-11-2023 03:17 PM
Hi will1969,
I finally resolved the issue after an hour of Canon support. Took forever to find the problem....The solution was to "disable the IP settings for IPv6" and to leave IPv4 alone. Here's how...
Home--LAN Settings--WiFi--Settings---Advanced--TCP-IP Settings---IPv4, IPv6....Click on IPv6 and "disable" it. This worked for me. I hope it helps you.
07-29-2022 01:12 PM
Hi will1969,
Does an error appear on the display of your imagePROGRAF PRO-300 ?
What version of Windows are you using?
If you are using a Mac, what version of OSX is installed?
Are you using your imagePROGRAF PRO-300 wirelessly?
Or are you using it with a USB cable?
07-29-2022 01:39 PM
Does it print a nozzle check and/or from other software?
01-11-2023 03:17 PM
Hi will1969,
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
