Canon ImageClass MF455dw wifi and local LAN simultaneous
HelloAnyone know how to use the WiFi and Local LAN connection simultaneously on the MF455dw printer?Thanks
Hello,I'm following this instructional YouTube video to set up my imageCLASS LBP6230dw.I did everything described in this video and it all went as expected until I got to 4:15, where clicking Next did not pull up my printer in the list of IPv4 Device...
I just got a new laptop, a MacBook Air 2020 running OS 13, and I am having the same problem as other Mac users with other printer models. The printing works, but the scanner says "Failed to open a connection to the device (-21345)." I logged into the...
Hi I bought the image class MF452dw I’ve set up my remote ui with pin,as I understand I should be able to print evan when not connected on same network.Problem is ones I go off the same Wi-Fi the printer is on i lose the printer connection. So how d...
Subject says it all. I have been through the posted procedure several times. Printer finds the wireless LAN but won't accept the password. I deleted the printer and reloaded the driver. Now the Mac OS can't find the printer. Tried using a USB ca...
I want to move this printer to another room. It is connected wirelessly to my Windows 11 laptop and my Android phone. Is there a way to do that while maintaining the wireless connections? Or do I have to reinstall in the new location? Thank you.
When I start "My Image Garden" the preliminary window pops up as well as the normal view of MIG behind it. When the preliminary (loading window?) finishes starting the program... It just disappears. I try again and yet again it loads MIG but then dis...
When I go into WiFi Setup, I select Manual Connect, I select the router, then the screen shows a router name with a blank line under it and a right arrow. I press OK and enter the password. Screen says connecting. I get the message failed to connect ...
I have tried every single option to get it connected to the wifi. It was working just fine two days ago. But now it has lost connection to the wifi. It keeps telling me the error every time I put the password in. The password has never been changed. ...
I recently got a new computer, my MX350 printer is working fine, wirelessly. Now I need to install MP Navigator so that I may scan documents. I have searched but cannot find a URL to download, other than from sites that are not Canon. Please help me ...
I am unable to install the MP Drivers on my Windows 10 Desktop. I used the installer 'm68n-win-g4000-1_01-ea34_2.exe' from the Canon website and it went OK up to the point that it said it was Registering Drivers. With the progress bar half or three ...
With my PRO-10, Windows 10, Print Studio as a plug-in from Photoshop using XPS driver. This combo has been working for years, now suddenly has stopped. I can enter all the data in Print Studio, hit Print and everything works great, except nothing is ...
Hello, I recently got a printer from Goodwill. It is a Canon MG 2120 I’ve been looking for a driver or software to use for my windows 10 laptop to come to a conclusion that the printer has been retired. Is there any software or driver available for t...
Recently I purchased an imageclass MF453DW. I can print and scan from the computer. I cannot scan from machine to computer because my computer does not show up on scanner screen. On my computer I can use the Network scan utility and see the machine ...
I have this model of printer I am trying to connect it to the new Internet of my home since I moved, I do all the steps but it does not let me put the Internet on it, if you could help me I would appreciate it
Subject | Author | Posted |
04-24-2024 10:59 AM | ||
04-24-2024 07:00 AM | ||
04-23-2024 02:15 PM | ||
04-21-2024 12:01 AM | ||
04-19-2024 11:39 AM |
