copy image from My Image Garden
Is it possible to copy an image from My Image Garden so I can use in a slide show? The copy/paste option is not working when I try to copy from image into Google Slides.
I need the IJ Scanner Utility on my new compter (under Windows 11). The website told me to look for a "driver package". I identifed the printer (TS8220) and Windows 11, and found no such package in the few items offered. Nor can I find a download ...
Hello All!Because our router only has 5 Ghz network, I have to use Wireless Direct with the Canon TS9521c printer.My MacBook Pro often, but not always, does not have the Canon TS9521c in the WiFi list. The printer says that wireless is enabled. When ...
Imageclass MF264dw II works fine with USB connection. but when I try it with wifi connection, the printer works fine, when I run MF Scan utility tool, it says "A scanner driver support this software is not installed".
Hi - have a canon c5250 and department ID set for multiple units to login to be charged back later. We have now added a few macbook airs to our crowd and the install is not working as anticipated. The canon is not recognized on the mac. Add the ip ad...
I am writing this post to seek assistance with connecting my Canon PIXMA TS3320 to my Chromebook. I have tried the following steps to troubleshoot the problem:Check your printer's compatibility: Make sure your printer is compatible with Chrome OS. Yo...
90% of the time when I try to print from my Macbook, iPhone, or android phone, the printer cannot be found. When I try to reconnect to the printer from my mac, it says "Unable to communicate with the printer at this time. Unable to connect to ‘Nikipe...
Trying to install a d570 printer on windows 10. The printer is setup on the network and other laptops/phones connect and print fine. I have tried both a network install and a usb install both fail with different errors. I have also tried the insta...
The printer direct connects to my phone. However, neither my MacBook nor my iMac can find it. The printer won’t connect to my wireless network.The Wi-Fi setting list says:Connection Enabled (disconnected). Then it gives a Network name (SSID), Frequ...
We have an ImageClass MF242dw monochrome printer. It has been working well for several months, but this morning, after printing several documents, it had an error message "Changed IP Address". This has happened before and we have been able to correct...
Recently purchased wireless printer PIXMA MG 3620. Downloaded the Canon print service app to my phone. Sometimes when I go to print there is another/different HP printer option displays as well. When that happens, it disables my Canon printer. It's ...
I have a Canon TS3122 printer. I'm using SUMo to update various pieces of software. SUMo tells me that I need new versions of the Canon IJ Network Scanner Selector EX2 and Canon IJ Scan Utility software pieces. SUMo says v2.0.10.328 and v.1.5.5.2 ...
I've just installed Windows 10 on my computer. I can print the stored files I have in the quick menu but somehow it won't printout any of the files I have stored under windows. Have any idea what's the problem?
Is there a desktop app I can use to choose what action I want the printer to perform, like scan, fax, etc. Something similar to HP Smart? I don't like using the little window on the printer, I prefer to do it from my laptop. Thanks in advance.
I’m trying to get my Imageclass MF6540 printer working on a new install of Windows 10 Professional, so far without success. Does anyone know where I might find driver for that? I’m trying to connect it up by USB. Thanks for any help
Subject | Author | Posted |
04-24-2024 07:00 AM | ||
04-23-2024 02:15 PM | ||
04-21-2024 12:01 AM | ||
04-19-2024 11:39 AM | ||
04-17-2024 09:13 PM |
