08-21-2023
		08:37 AM
		09:28 AM
My laptop died that I use to print from Professional Print & Layout.
I can access the hold hard drive as a USB drive and am trying to figure out where to find all my customized settings so I can move them to the new laptop.
Help is greatly appreciated!
Tim
08-21-2023 10:35 AM
@tpayne10 wrote:My laptop died that I use to print from Professional Print & Layout.
Tim
I downloaded and installed PP&L before I realized it won't work with my printer.
You could look here (need to show hidden folders):
A similar path works for me with PSP.
08-21-2023 08:58 AM
Are you using a Mac or Windows PC? For a Mac, always best to use Migration Assistant which should preserve all settings from one computer to the next.
08-21-2023 09:06 AM
old laptop was Win10, new laptop is Win11
What is Migration Assistant and will it work for my particular issue?
08-21-2023 09:34 AM
That's only if you have a Mac, which you don't. Migration Assistant is a special application Apple created to make moving from one Mac to the next a seamless process. I'm not familiar if there's any equivalent for Windows PCs.
08-21-2023 10:35 AM
Tim
08-21-2023 10:45 AM
I did copy the folder you referenced. However, after going back into the app, I had to do a little setup to be able to see layouts. I had to change the Layout Mode from Single Image to Multiple Images. Thanks!
