MF Toolbox doesn't work on Windows 10
mj1856
I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
I can no longer scan using the MF Toolbox utility.   I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine.  After the upgrade, I get "Cannot communicate with the scanner" error dialog:
I thought I would try to reinstall the MF Toolbox utility, but there are two problems.
1) The downloads page shows no downloads for Windows 10 for this printer. This should be updated.
2) I downloaded the one for Windows 8.1, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
I've also tried to uninstall the existing MF Toolbox first, and it also hangs at this same dialog.
I've also tried various other things without success:
- Connecting via USB instead of Network.  It detects the scanner, and MF Toolbox can switch to that device, but it still gives a communications error.
- Trying the built-in Windows Scan app instead of MF Toolbox.  It uses the WIA driver.  It barely starts to scan, then immediately cancels.
Please Canon - forward this to your engineers and provide a fix asap.  I cannot use my scanner on Windows 10.
(I can use the printer functionality just fine.)
435 REPLIES 435
Mohafez
Firstly you need to download the latest Canon MF Toolbox from the Canon website. Go to this link to enter your scanner’s model and follow the on-screen instructions to download the utility.
Once downloaded, install the application.
Once installed, right click on the application icon and select
Move to the compatibility tab and select the checkbox behind “Run this program in compatibility mode for”
From the drop-down list, select “Windows 7”
Firstly you need to download the latest Canon MF Toolbox from the Canon website. .
joel1952
I installed Windows Scan on an old computer
<Outside link removed per Community guidelines.>
It installed easier and faster than the Canon software. It's easier to use. Maybe it doesn't have as many options as Canon, but it has all the basics.
Did I say "easy and fast to install and use"?
scotty2541
The solution  to my issue, which is :"The MF Tool box that is supported by the scanner may not be installed... " is:
Go to "C:\Program Files\Canon\Canon MF Network Scan Utility\CNMFSUT6.EXE"  right click, and set the thing to "Run As Administrator".
When the installer ran, it should have done this.   And Canon should actually care about their customers having issues.
I had the same error with my MF631Cn under Windows 11 for months: "Cannot communicate with the scanner".
The WIA service solution by Piers_A worked (permalink #M2130).
Thank you very much
EDIT: wrong; my issue was in fact fixed by simply pluging the usb plug in the "right" usb port on the computer. I was expecting the scanner to work on any usb port; for some reason, it isn't. So nothing to do with the WIA Service account. Thanks anyway.
I found a solution to this problem. Go to C:\Program Files\Canon\Canon MF Network Scan Utility
And then right-click on CNMFSUT6.EXE, properties, security, edit permission Everyone Full control.
Do the same with the CNMFSUR6.dll file
