Is the battery problem of the 1100 solved in the 1300?
The PowerShot A1100is has received numerous complaints about batteries causing "Change Batteries" message even when new batteries inserted. Has that isse been fixed in the PowerShot 1300is?
HOW DO I DELETE PHOTOS FROM THE MEMORY CARD?
I have a Canon S100. The lens will not retract. I get a Lens Error message. Will shut down automatically. Restart Camera.It is not shutting down, I cannot restart the camera.
Directions for setting up wifi on PowerShot S110..... please!
Card is not locked.How to make the camera default so the a card is always unlocked.?
the lcd display on my powershot a3300is is dark.Older pics show up ok, but new pics don't.
Hello & Merry Christmas to all, Trying to find out what flash is made to work with the SX50. Seems like unless you have a DSLR, there isn't much info. I checked under Canon PowerShot. I'm very new...
Will my speedlite 380EX work with a powershot sx50 HS?
I am using a Windows Vista 32-bit operating system. When I attempt to install the software included with my G15, the installation program crashes with a general error message from Windows. I spoke with Canon Support and was told that this is my pro...
The subject line says it all:-)
memory card error
I took about 8 pictures and the LCD screen went white and will not work
When I plug the camera to the computer the window does not open to allow me to down load pictures. It has always worked in the past. A570 IS is the camera. I also tried to insert the disc and it does notopen the window either.
My guide is in Spanish. Did not get an English one. Therefore, I can't use the camera at all. Don't have the proper plugs to charge the battery and its dead as a doornail. Help!!!!! Got port for computer...got some other cord that doesn't fit in th...
I have a 5Dmkii and use it regularly with my Elinchrom studio flashes equipped with a radio trigger. I just had occasion to use my G12 on a shoot and tried it with the radio trigger for the flash heads. It wouldn't fire. I ended up having to go with...
Subject | Author | Posted |
06-11-2024 10:43 AM | ||
06-10-2024 07:22 PM | ||
06-04-2024 01:30 AM | ||
05-21-2024 12:37 PM | ||
05-16-2024 10:33 AM |
