Problem with S2 IS
Hi,the problem is that I cannot see an image through either the view finder or on the LCD screen. I have changed the batteries and also used a new SD card. Nothing shows up on the FAQ's about this problem! any one?
Hi, I bought the cameraq a while back and I thought to buy some filters. I like to buy oroginal as much as possible, and imagine my surprise when I found out the PL filter from Canon was $390!...How is it posible?Can somebody -specially somebody repr...
HiI need help to buy a compact digital camera with high quality stills and full HD video recording capabilities.I found the following models: G15, S110, SX280 HS, SX260 HS.which one should I choose? which one is better?Best Regards,Barak Shimoni
Any ideas why my Setup won't launch on my Mac that has a current operating system? It flashes and then nothing happens.
Hi!I have gotten all the way through to the Canon Utilities Camera Window DC, and when I click the "edit web services" button I get a pop up window that says "Update the application. To set your camer, update CameraWindow DC".I cannot get past this s...
I have owned a Canon SX50 HS for nearly a year now and have noticed a dark smudge has appeared top right on some of my photos. It only happens on C1 and C2 settings when zooming out to 50X. It has not appeared on other settings (YET). It has also see...
I have a PowerShot SX170 IS. It was dropped in water for 4-5 seconds, but it didn't go all the way under and the lens was above water.It was off, and I immediatly took it out, took the battery and sd card out. I put it in a bowl or rice for 28-30 hou...
I just purchased my G16 a week ago and it is still on it's first charge. The batterry level would show full charge when shooting stills but when I would record video the battery indicator would start flashing red with 1 bar within a minute of recordi...
I have a Canon SX50 HS and it has stopped connecting to my laptop. I have changed the USB cable. Any suggestions
Despite following all instructions from the Canon manual that came with my CanonSZ 280 I cannot get the WiFi function to work. Any help would be appreciated.
I cannot crop pictures on the Canon SX50 HS camera. I receiave the error message "Cannot Modify image". Can someone suggest the way to do this?
how to change the owner name and/or author name on camera and photos on a sx50
My viewfinder does not fill the screen on most settings. When I rotate through settings, and look through viewfinder, it will initially be full screen, then reduce to fit about half screen in a portrait style view with black on either side of the vie...
Subject | Author | Posted |
04-23-2024 11:22 AM | ||
04-22-2024 02:11 PM | ||
04-11-2024 10:55 AM | ||
04-06-2024 09:35 PM | ||
04-05-2024 07:50 AM |
