01-24-2015 05:28 PM
ELPH 330 HS is rated 12 MPixel, but the jpeg images exported with Canon Utilities CameraWindow are only 1600 x 1200 pixels. I can't find where to set the resolution of the exported images, either on the camera or the software.
My real problem is that these images will not display from a CD with my Blu-ray player, where images from a previous camera will. The only difference I see is that the ELPH 330 HS images are ~500 KB, but from the previous camera ~ 4000 KB. I wonder if the ELPH images are too low resolutions for Blu-ray/High Def.
01-24-2015 06:13 PM
Check your aspect ratio if you have it set to 16:9 then 1600x1200 is the max. 4:3 is where you want to be to get up to 4000x3000.
