i-SENSYS LBP6020 Not Working After Upgrade to Windows 10
abrar2000
my printer is lbp6020b it was working normally at widows 7, I bought a new computer it works at windows 10, but my printer is not responding to print.
jqwegf
After I updated the firmware and driver
Nothing was working for me and I was going in circles. I could not even log into Remote UI as it was unavailable.
I was trying to verify that both the printer and my mac were on the same wireless network (they had to be) and therefore decided to follow this link
In following this link, FINALLY, Ventura (13.2) found Canon LBP622CDW
Hope this helps :
So Go to Settings
General
Sharing
Printer Sharing - it will take you to the Printer/Scanner setting, but this time it will find the printer
7 REPLIES 7
dexman335
Mentor
Mentor
Are the latest drivers downloaded from the Canon website and been installed on the new computer? Are there any software updates pending for the unit? 🤔
yes, I do. but the message communication error.
Ok, when preparing to print, say, you try to print this webpage by pressing "Ctrl" and "P" is the printer the target device, or is something else the target?
Is the printer connected to the computer via direct cable or Wi-Fi?
abrar2000
Yes, I do. the printer is connected to the computer via a direct cable.
My suspicion is that the incorrect port is selected. Try changing the selected port to see if any can communicate with the printer.
jqwegf
Hope this helps :
So Go to Settings
General
Sharing
Thank you for posting/sharing the resolution! 🙂
