07-19-2016 09:14 AM
07-19-2016 09:50 AM
07-20-2016 01:28 PM
Network cable, or local connection via USB? Color or black & white? Inkjet or Laserjet?
Did you know that inks for inkjets come in two basic styles? First, there are the real cheap inkjet cartridges that dry out in a few weeks, whether you use the printer or not.
Second, there are the larger capacity [and more costly] cartridges that do not dry out, which means printers that use them are less costly to operate over the long run.
Finally, I recommend a laserjet printer, one that uses toner. You can print thousands and thousands of sheets from one cartridge, and the toner cartridge will last for years. I am currently in my 6th year with the same printer and original cartridge. I have gone through four reams of paper with it, and working on a fifth. I use separate scanner, or simply take a photo.
07-20-2016 06:13 PM
07-20-2016 06:27 PM
@Lbro7 wrote:
I will check out the laser jet.
Using a USB connection to computers
I also didnt like the HP Envey as i ustp print on envalopes.... addresses. And it refused to print the envalopes my wife got as there size wasent on the print programs sizes. ...... too smart
I don't use my printer a whole, whole lot. Mainly to print discount coupons, recipes, ticket receipts and other small stuff. I purchased a B&W laserjet because I felt that I didn't need color [multiple cartridges to buy] with the expected printing volume I would do. I waited for a sale and bought it for half off the list price.
I am surprised to hear that you could not find a template to print on a given envelope size. Envelopes are pretty standard, unless the printer was more photo oriented than business oriented. I use a separate photo printer, BTW. It's an inkjet [Pixma Pro-100] that uses the more expensive inks, which do not dry out as quickly as the cheap ones.
07-20-2016 09:48 PM
07-24-2016 09:07 PM
05-30-2017 10:42 AM
If you are still looking for solution deciding what type of printer you are looking for, you can refer to this page, they got detail information guiding you what will be the best !
https://www.123inkcartridges.ca/topics/659-how-to-choose-the-right-printer
