06-30-2020 07:24 PM
Worked fine previously. Now unit does not stay on. When switched on, power light gives one long flash, gps light gives 3 short flashes, then nothing. No lights, camera doesn't see unit in hot shoe and computer doesn't see unit on USB.
06-30-2020 07:28 PM
@AheadAir wrote:Worked fine previously. Now unit does not stay on. When switched on, power light gives one long flash, gps light gives 3 short flashes, then nothing. No lights, camera doesn't see unit in hot shoe and computer doesn't see unit on USB.
Sounds like the flashes might be an error code. What does the User Manual say about it? Is it able to receive a signal?
06-30-2020 10:07 PM
I don't think the flashes are an error code. I seem to recall that it has always flashed like that at power up. The battery light should flash slowly and the gps light should flash every 3 seconds when it has a lock. There is no reference in the manual to any POST flashing or anything other than normal operation.
07-01-2020 05:06 AM
@AheadAir wrote:I don't think the flashes are an error code..
It might mean low battery.
10-21-2021 10:56 AM
10-21-2021 07:14 PM
It's been almost a year and a half. Did you ever contact Canon?
11-02-2021 08:04 AM - edited 11-03-2021 12:21 AM
@AheadAir wrote:Worked fine previously. Now unit does not stay on. When switched on, power light gives one long flash, gps light gives 3 short flashes, then nothing. No lights, camera doesn't see unit in hot shoe and computer doesn't see unit on USB. mymilestonecard
I have the same problem with facing same issue but no response from anyone and couldn't find this topic troubleshooting in search engine.
11-02-2021 08:09 AM
Call 1-800-OK-CANON
