EOS 100D Slide Music Background music
How do I get music on my Slide Shows from my WIndows 7 PC to my Canon EOS 100D? Thanks,RR
Hello. My EOS 1Ds Mk II has a problem. The rear control dial doesn't seem to work, in that it never changes any setting in shooting mode. In all other respects it works fine, but in M mode for instance, the front control dial changes shutter speed bu...
I just upgraded to a EOS Rebel T5i (my old camera was a SX20 IS). Although I am going through the manual, I have not been able to find the answer to several questions. This is one of them -- I apologize upfront for the Newbie questions I usually l...
Hi As part of a vegetation monitoring program in nature reserves, I examine changes by using a time series of photos. I use a modified rebel i3, in which the internal IR filter has been removed (http://www.maxmax.com/ircameraconversions.htm). I use a...
I have a canon 50D
I just read the T3i cannot autofocus in video mode, true?On T5i can the shutter speed be set when taking video? Sometimes I need fast shutter so fast moving objects are not blurred.
When I first got my camera and took multiple pictures, when downloading them to my computer they loaded 50 pictures to a folder. Now when I load my pictures to my computer it loads each individual picture in a separate file. Is there a way to change ...
Hi there, I have a canon eos rebel t3, I'm trying to figure out what is going on with this for a friend and trying to fix it. I had to fix a ribbon cable that her husband broke trying to fix a button that he thought was broken because the disp button...
Can Error 05, flash will not pop up, be fixed Without returning to Canon?
I do nightclub photography and I've had my t3i for about 2 years now and I use the 550 ex. Recently the red light doesn't blink when I try to get a focus in low light using the kit lens.I know the red light does work because I used it with a trigger...
Hi. I'm just looking for other people who have this issue. On my refurbished T4i, which I've just begun using, whenever I open the SD card compartment, the white balance resets to the dreaded AWB setting. It's like clockwork. A Canon rep told me ...
I'm a Nikon shooter when it comes to DSLR's. Stop booooing! I have a friend that shoots Canon gear, 5D Mark2 and 5D Mark3. I mentioned to her that she should be shooting in 16 bit RAW not 8 and with the Nikon's I can set that option either way in RA...
I've downloaded the EOS Remote app to my iphone5. I've followed the EOS instructions to Enable WiFi on the EOS 70D. My iphone doesn't find the EOS SSID. Has anyone run into this? What did you do to solve it?
Hi, I had the misfortune of getting water in my 60D and now it's broken. It seems that in non-creative modes P, Av, Tv, M, B, C and Video the shutter button acts as if it's half-pressed. Because of this, absolutely none of the other buttons on the ca...
My computer thinks my 7d is a Logitech Headphone. I've tried uninstalling all the usb drivers, but windows 7 (64 bit) keeps reinstalling drivers for the headphone instead of the camera. It used to work fine, now all of a sudden, this.
Subject | Author | Posted |
04-23-2024 01:41 PM | ||
04-15-2024 12:09 AM | ||
03-30-2024 12:16 AM | ||
03-18-2024 02:24 PM | ||
03-17-2024 11:40 AM |
