Can I upgrade the firmware on my T1i to support SDXC cards?
I want to shoot some video on my T1i and would like to use an SDXC card. My camera won't recognize or format that kind of card. Is there a firmware upgrade/ workaround?
I recently tried turning on my T31 and it wouldn't power on. I have two batteries, so I assumed both were dead and placed one to charge. Once the charge light switched from orange (charge) to green (full), I inserted the battery back into the camer...
I have a ton of questions. I have a 6D and I was wondering how to get my subject brighter when I take pictures with the sun in the background. I don't alway have problems when the sun isn't as bright or if it's setting, etc., but when it's really bri...
So i have a t5i. When i plug in my rode video mic pro to use, and turn it on i go to the "sound recording" area in menu to manually adjust the levels. However, under "sound recording", the only options that come up are "on" and "off" .... no "manual"...
I have a Celestron 5se + canon 650d. They are mated with the celestron t-ring and the 93625 t-adaptor.I want to take magnified photos of planets with the camera. But if I add an eyepiece to the t-adaptor, everything gets blur.Here are some scenarios ...
track and field all day events mostly sunny until sun goes down. using a canon 3ti 55-250mm lens. what is a good starting point for the best pictures?
5d MKIII with 17-35 f2.8 lens I get this a few times in my pictures where an area of the photos is grainy and the rest is sharp. to the bottom right of this image it has as grainy area and the rest of the picture is clear. I enlarged the area to show...
Finishing up a session yesterday and the last few photos had a bright streak across the top of the image. I cleaned the sensor (not manually) changed lens, memory card, etc. and still there is a line. My warranty is soon due out. I hope this is somet...
Canon 6D only recently started shooting incredibly small image files. When set to large jpeg, which should produce 20MB files, the results are now between 4MB and 5MB image files. Medium and small image jpeg settings are also a lot smaller than what ...
My Canon T6I Overexposed the photos when is in AV with Teleconverter attached. If i am on Live View mode no problem. The same with the autofocus. If the camera it's not on live view can't get on good focus. The same with the Tamron teleconverters no...
Hello all, I am new here and this is my first post. A couple days ago I purchased a new EOS 70D camera. This is my first "real" camera. I have been doing aerial photography with drones for a few years now. This camera so far is great! All the feature...
I'm trying to set my T5i to work with studio flashes. I bought a Vello hotshoe adapter and set it up on the camera. The strobes work, but only if I turn Live View off. If the screen is on, the flashes won't fire.Hopefully I'm missing something here, ...
I have the Canon EOS Rebel XTi and it has worked fine forever. Now, when I try to take a picture on auto focus, the lens will focus, but it will not take the picture. In the view area when I'm trying to take the picture, it always has the number 9 in...
Hello all, new member of the canon community and also new to photography. I started off using a Minolta Maxxum 5xi (35mm SLR and still planning on using it) and recently acquired a Canon Digital Rebel XTI from my Aunt. I took up photography as a hobb...
Subject | Author | Posted |
05-16-2024 11:03 AM | ||
05-14-2024 11:01 AM | ||
05-12-2024 09:21 PM | ||
05-11-2024 10:35 PM | ||
05-10-2024 09:22 PM |
