canon eos rebel t3 no longer connects to eyefi mobi card
i have done a hard reset of my camera, re-enabled the connection, but still does not connect tl the card and transmit WiFi signal so i can transmit images
Hello!I am user of Canon EOS Rebel T 5i.With 55-250mm and 18 - 55 mm lenses I used to get good quality images. However of late I have problem in getting sharp and clear images. I use power glasses. As suggested by a fellow photographer, I adjusted di...
Dropped the camera and now it has a crack about one inch long next to the "Canon" logo and below the flash attachment. The camera is working fine but I am gong to send it to Canon for a check. My question is, Any concern that humidity might buit insi...
Recently an "alleged professional photographer" told me that if I was using a lens that had an aperature or f5.6 that I could not set the aperature to anything but 5.6. I think this may be not true based on some photos I took with my 70D and a 400mm ...
Hey everyone,I have two batteries for my 7D and both of them trigger the "unable to communicate with battery" error when I put a charged battery in the camera.I did some searching and found the YouTube video "Canon 7D "cannot communicate with battery...
Dear All, How can I shoot 25FPS on my 5D Mark ii? Will I need to install Magic Lantern (I have once tried and failed unfortunately)? Thank you very much in advance!!Marc
can someone help me by providing the dynamic range of exposure for t3i. (dynami range - Lowest and highest exposure range in terms of f-stops for a given scene)
Hello: Situation:5D Mark iii is partially unresponsive. Background:I was at Isle Royale last week shooting wildlife and landscape. The morning prior to leaving, I was shooting a family of ducks. My 32GB SanDisk Exstreme Pro CF card was nearly full,...
Have not noticed this before but when I power on my 70d the top LCD screen displays manual focus for a second and then goes back into either one shot, servo, or whatever focus mode I was in earlier. Is this normal behaviour for a 70d? My lens is set ...
Really hoping someone can Help! I have had my Mark iii for a little over a year and have hardly been able to use it for work due to the way it picks up these massive reflections off of every single white surface (table linens, a piece of paper, the b...
I own the Canon 1100D, and so far I've taken photos in Landscape Mode. Recently, I take pictures using Manual Mode,and whenever I connect my camera to my pc, it won't show my photos unless I shot it using Landscape Mode. Even if I take 10 Manually sh...
HI. just received my Canon 1DX Mark II nd with it the WFT-E8 (a). i very familiar with canon EOS cameras, but i am clueless when it comes to WFT-E8 and getting it to talk/transfer files to my Macbook Pro. the device came with a CD (which is useless t...
Hi , i have a problem with my Canon eos10. I had the app "canon camera connect" and it worked well with my phone, but then suddenly deleted the app and redownloaded it. Now it shows that i am connected with wifi of camera but the app says "operate th...
I cannot connect my Canon 6D with my iPhone 5 even after I installed the EOS Remote App. Camera's WiFi function is or was configured and I think I followed all the steps to try to connect camera to phone so I can transfer my photos.Thank you.
Subject | Author | Posted |
05-14-2024 11:01 AM | ||
05-12-2024 09:21 PM | ||
05-11-2024 10:35 PM | ||
05-10-2024 09:22 PM | ||
05-06-2024 05:08 AM |
