Can't get my camera to focus
Hi y'all,. I'm new to photoboothing and I can't figure out what setting I put my Canon Rebel T5 on so that everyone stays in focus and don't come out blurry. Can someone please give me some pointers ?
I don't understand why I all the time got a flashing point beside the focuspoint I'm using. When I move my focuspoint, the other flashing point keeps the same positition. Just flashing. How do I turn this off. I don't know what It's good for. My cam...
Hi guys,I recently purchased the Canon 6D Mark II.Whenever I try to use my Godox TT658c flash on the camera or off camera with the X1 transmitter I get an AI Bounce warning on the LCD screen. I cannot change any settings as long as this warning is di...
I am trying to get my Canon 6D to lock on to a moving subject in the dark. I am using the 430ex II flash. The subjects will be moving towards us within twenty feet. I am using a Canon 50mm 1.4 lens. Unfortunately my flash infrared meter was not w...
I recently updated the firmware on my 7D to 2.0.6, and discovered on a recent shoot that I had lost the ability to do anything in Manual. Upon closer inspection, it now looks like I have lost the ability to select "Creative Auto", Aperature Priotrit...
While using the camera 5D Mark 3 and 500 mm lense suddenly facing the problem for auto focus,not focus properly if any advise to solve the issue around three yeas old camera and new lense
Two Quick Questions: 1. I viewed a video that stated that when using BBF with AI Servo, only the center focus point is active. So if you are tracking a bird in flght, and if the center point is not on the subject, you will lose focus. Is that cor...
When I go into the menu, Expo.comp./AEB, I can use the left and right arrow keys to change the exposure compensation. but if I turn the dial to try to set aeb, the menu disappears completely and I'm taken back out to the main info screen, where turni...
My EOS 700D doesn't properly focus. I have my camer for over a year and it worked perfectly until now. The problem only occurs when i try to take pictures of the horizon or when the picture is half sky and half mountains or anything else. When i try ...
I bought new Canon EOS 70D and after shoting few videos in low light I noticed very unpleasant thing. All video files (with settings: ISO 1000, user profile with lowest contrast and saturation or cinestyle, no noise reduction) have vertical lines. Yo...
I bought a T6i a few days ago and received it yesterday. I have yet to even put 50 shots on the camera and I've noticed when I hold the side grip of the camera it makes a tap/creek sound. Almost like the panel is 100% connected. Is this normal? I kno...
I own a T3i for about 18months. It's been perfectly fine till it does not turn on at all this past Fri after taking pictures at my sister's HS graduation. It does not make a sound. I recharged the battery and tried again, I took the card out then put...
Suddenly my camera will not focus or take photos. I am aware it will not take the photo because the AF isnt working. I have tried MF which only works sometimes. I have also tried all shooting modes (manual works more often than the others). The camer...
I use two iOS apps (Moves and GEOTagr) to add location data to my EOS80d photos.The location shows up correctly on the photos in my photo library on my iPad.When backed up to google photos, the location data is removed!!What happens here? How is this...
Subject | Author | Posted |
04-29-2024 05:58 AM | ||
04-28-2024 09:09 AM | ||
04-27-2024 08:20 PM | ||
04-25-2024 12:42 PM | ||
04-15-2024 12:09 AM |
