EOS DSLR & Mirrorless Cameras
Canon EOS 7D Mark II Soft focus
Hi, I have had a Canon EOS 50D for a long time and decided to upgrade to a 7D Mark II since this fitted my need for indoor sports photography. I also purchhased a used Canon 70-200 f/2.8 L USM. But I am not happpy with the images, they are not sharp ...
magmo by Contributor
  • 6769 Views
  • 21 replies
Canon Rebel T3i not working
First day I bought the camera it was working and then the next day it started displaying "error 30" on the screen. I've been told that this usually means the shutter isn't functioning but I took off my lens and tried taking pictures without the shutt...
peckc97 by Apprentice
  • 2496 Views
  • 2 replies
Resolved! 7D using tripod arm problem
When I used my tripod arm with my 7d to take a downward photo of an old photo on a table the photo took well and filled my screen when it showed in the view finder window. However, when I reviewed it, the photo showed sideways, the opposite way in wh...
Glynn by Apprentice
  • 2355 Views
  • 2 replies
Canon 6d Mark II
I bought the Canon 6D mark II in August 2017 due to a malfunction on my Canon 80D with 2 months.What happens with the Canon 6D Mark II, with the same settings as the Canon 80D the images go very bad, foggy and unfocused, the lenses used were the cano...
6D MkII + 24-105 f4 II sharpness problem
Hi, recently switched from a Nikon D610 to EOS 6dMkII with a 24-105 f4 II lens. Compared to my previous camera, I noticed that the sharpness of the photos is much much lower (before I had a 24-120 f4 Nikkor, so quite similar).Also shooting with tripo...
Simone81 by Apprentice
  • 7760 Views
  • 10 replies
Resolved! 5d mark iv cleaning
when i look through the viewfinder, i see some debris.  it is not appearing on my pictures so i can assume that it is not on my sensor.  i believe the debris is on the top internal component.  i'm not sure what its called.  it doesn't appear to be a ...
mikehorb by Apprentice
  • 4428 Views
  • 5 replies
What to buy ?
I have saved up $800 and want to buy  a camera, I want a FF to replace my not so working XTI. family members have some high end models but I wanna have my own . There aren't a lot of options. I can only buy a used one. For the tight budget, I can onl...
huskyC by Enthusiast
  • 3021 Views
  • 10 replies
Resolved! Canon Rebel t5 Remote jack problem
Hey there. Okay so here's the thing. I contacted a friend of mine who has a T5 and had managed to film a documentary with crisp clear vocal audio. I asked her how she achieved this since the T5 doesn't have an external 3.5mm microphone port.She told ...
Aeosgames by Contributor
  • 26835 Views
  • 15 replies
T3i stops transmitting over Hdmi
Hi! So... I was trying to set my camera for a magician. I connected the camera over hdmi to a projector and disabled the "auto power off" function and set it to manual live view. Turns up it stopped after about 30 minutes. When i went check it, it to...
Fadafoca by Apprentice
  • 2288 Views
  • 2 replies
6D MarkII issue with image upload
I need help in recovering images on a new SanDisk sd card.  The images can be seen on camera screen with the card, but cannot be seen when uploaded to computer.  The images come in as IMG_0195.CR2 but when trying to open an image in Photo Gallery i g...
JCovert2 by Apprentice
  • 3520 Views
  • 3 replies
T6i WiFi SSID
When setting up the WiFi info on an enabled DSLR, you set the SSID and password info and whatever other parameters needed. Being clever, I wanted to put “T6i-Fi.” However, after setting everything and seeing the camera’s SSID on my phone’s WiFi Setti...
Canon rebel t5
I own a canon eos rebel t5, and I have had it for about a year. My last battery charger quit working. I got a new one, and now the camera will not turn on. It will start making a noise like it's trying to auto focus, but it keeps repeating the same n...
canon lens
I HAVE AN EOS REBEL T3I WITH AN IMAGE STABILIZER  18 --55 LENS.I ALSO HAVE A CANON EFS55-250 IMAGE STABILIZER LENSWILL THEY FIT THE CANON EOS REBEL T5I
bgant4 by Apprentice
  • 6680 Views
  • 7 replies
