EOS DSLR & Mirrorless Cameras
EOS 70D sound recording options
So on the canon 70d - The sound recording option- on this particular camera gives options of ‘on’ or ‘off’ - every other canon I’ve worked with, and I own 3 70D’s, the options are ‘auto’ and ‘manual’   I need ‘auto’ and ‘manual’ to hook up my sound g...
Ry3 by Apprentice
  • 268 Views
  • 2 replies
Resolved! EOS R8 Where is sound recording menu
Where is the R8 sound recording menu? The diagram and instructions shows where but I cannot find the menu in my camera. I have sound record on/off only. Not the full menu. The manual also says "Use" followed by a camera icon. What does that mean?  th...
Cannot Insert SD Card Into 5D MKIV
Hi... As the subject heading notes I cannot insert my SD card into the SD memory card slot. The CF card goes in just fine next to it. The SD card goes about 80% of the way in. I see no obstructions, have tried a different SD cards. No luck. Have had ...
sfarson by Contributor
  • 427 Views
  • 6 replies
EOS 5Ds stopped reading SD card slot
I ordered the w-e1 wi-fi converter. I realized I needed to update the firmware. After doing so, the wi-fi still didn't work I didn't know if there was a way to test it to see if it worked elsewhere, but I took it out and put the memory card from that...
