CF/CF Fast Card Reader
will be using my 1DX Mll on wilderness trip and need aa portable external hard drive to save images and free up space. Any recomendations for good external H/D
My EOS R5 lost several functions today including loss of all menus for camera settings and playback, loss of mode functions, loss of auto focus, loss of metering, no shutter operation. I was able to take pictures in manual focus mode but could not re...
In my viewfinder, I have a number 9 in brackets next to my ISO reading.[9]It looks like this in the manual:I have a T8i, and I don't know if this is unique to this model, or if it's something that all Rebels show.Can anyone tell me what this is? Stev...
I just had my 5ds R serviced by canon for an unrelated issue. Since getting the camera back, every time I switch batteries, the camera resets the date and time. It also seems to resets to different dates/ times. Sometimes it's 1999/01/01 and today it...
I've been all over the site and the $89 accessory kit says it works with T7 cameras. I don't see one that explicitly says T8. Will that one work with the T8? I just want to make sure I buy the correct cables and power supply. For those of you who are...
Hi I am new to this so please be kind I got a 6D ii to replace my old 7D. I notice all of a sudden that when I try to set my shutter speed in th Q menu, it only goes as far as 1/180 and no more, though I could before. Obviously I have pressed/set s...
So the obvious bit first--have been livestreaming off-and-on the past few years, had always been looking into getting a better quality camera with total control. Bought the M50 Mark II as my first semi-professional DSLR and primarily plan to use it f...
I'm getting a clean image using my EOS M50 as a webcam via zoom...Was there an update to Webcam Utility because everything I read on forum says the M50 does not have a clean hdmi.
I Hi, I am having several problems . 1, Cannot change any settings in Modes other than Auto(which I know changes itself. And still does). Also cannot review Pictures in any other mode than Auto.. 2, Cannot access Menu from any mode other than Auto. A...
Hey there, smart people!So, after many months of them being O.O.S., I was FINALLY able to get my hands on an R5 as a replacement for my aging 5D MKIII. With that, having a rear touchscreen is a brand new option for me.So, is the question in the SUBJE...
I have my GPS set to update every 5 seconds but, in practice, it often takes much longer. The camera is on an open boat in a non-metallic case. I did not have this problem with my previous camera, an ancient Sony a77v, traveling the same route. Is th...
I was just wondering if anyone can please recommend a high-powered telephoto zoom lens that is compatible with the EOS Rebel T7i I'm looking for something 400mm or higher for photographing the moon. If possible I'm hoping to find one for under $500 b...
I have an 18-80 cinema lens and suddenly the AF servo stopped working as well as communication between the lens and a 1DX Mark II. I have a backup 18-80 and this one is also doing the same thing. Suggestions?
Just received my Mark IV, but for some reason my 50mm lens AF (Auto Focus) won’t work. It won’t focus on the pointed area, it won’t even bleep. What could be the problem?Thank you
Hello all. I recently got an EOS 90D. It shoots video at 29p. But I am told there is an applicayion I can get so the camera will also be able to shoot at 24p. Honestly, I am so ignorant here that I'm not even sure what exactly an "application" in thi...
Subject | Author | Posted |
04-28-2024 07:40 AM | ||
04-28-2024 07:24 AM | ||
04-28-2024 06:01 AM | ||
04-28-2024 01:45 AM | ||
04-27-2024 08:20 PM |
