R5 vs R5MII
what are the advantages of one over the other ??
I took a load of photos yesterday using a memory card. Half of the images are fine but the others, despite there being something there as they are all substantial file sizes, won't display or download. It says the format is not supported!I'm so ups...
Hello! I have no doubt this is going to make me look utterly stupid but I just sent in my #EOS 5D Mark III in for the first time for maintenance and got this back.”Shot count:217908. Mirror count:218363”Can someone clarify what this means? Is it good...
I am having an issue with my camera in terms of it not being ready for podcasts. It used to be that when I turned the camera on, it was simply ready to go, nothing had to be done to get it ready to stream. Now everytime I turn it on, it reverts to th...
Hello,I recently purchased the Canon R8 for streaming, and after trying everything... Windows 11 is unable to detect the camera. I set it to streaming in the wrench menu, disabled wifi, disabled power shutoff settings, and installed the latest driver...
I cull images as I go, and when I get to import into my computer, I see all images taken, including the deleted ones. Is there a reason for this? Does one card slot keep all the images as a backup while the other stays culled? I'm using a Canon r6. T...
I have a Canon EOS R50, and I'm trying to use it with a Tokina 400mm F8 Reflex MF lens.The lens is manual focus only, and does not have an AF/MF switch.If I mount the lens, and try to use it, the shutter does not trigger. I'm assuming that this is be...
Hi,I bought a Canon M50, and just recently realized that when I try to use the external 3.5mm audio input jack it gives (ie. pushes in) about 1 - 1.5mm. I also noticed that the external mic doesn't record sound which leads me to believe that the jac...
So I just plugged in my new W-E1 Wi-fi card, I follow all the instructions and I can connect to it with my phone with no problem. I can even access the pictures on camera and download them too my phone via the Canon Camera Connect app. However when I...
Hi all,I have been enjoying photography more and more over the last few years and I am thinking it is time to upgrade. I spend a lot of time hiking, offroading, and taking some water sports photography. I really enjoy adventure photgraphy and this is...
on my R5, on the q button, my drive mode is flashing. It only flashes on high speed and high speed +Never did this before.
Hello, I have a Canon EOS 1D Mark II with a WFT-E8B and i want to upload photos directly from the camera to an ftp folder. My camera successfully detects the WFT-E8B wireless transmitter. I can see the Wireless Mac Address in the Function Settings.T...
I turned my camera on today to test some settings that I plan on using for the eclipse. As soon as I turn it on, the 2-second timer is activated and takes a shot after the time is up. No problem, I'll just change the appropriate settings and get back...
Hi folks! I'm coming from an R5, and struggling with 2 issues. Setting up my Focus, and OCF. Have spent a few hours searching, sorry if it's been asked already. 1st - Running a Godox X Pro II trigger. On my R5, when I turned the trigger on, the expos...
Subject | Author | Posted |
05-20-2024 01:44 PM | ||
05-20-2024 01:44 AM | ||
05-18-2024 04:44 PM | ||
05-12-2024 09:21 PM | ||
05-11-2024 10:35 PM |
