04-12-2018 11:08 AM
04-17-2018 03:35 PM - edited 04-17-2018 03:41 PM
@Vineetgarg_99wrote:
Above BIF capture is really great, please share the setting, it will further improve my skill.
Which lens and body you are using?
There are no right or wrong ways to do anything...rather there's an easier or harder way to do it for you. It's different for each person. To me, the pictures of birds flying shown are the easy ones...any method will work for an experienced shooter...the shots that require split second timing are the ones that will require the easier way.
Try a single point focus and spot metering on these and see how well you can do it... The first picture - 2 butterflies were dancing a courtship dance in the open. This was one of the hardest Autofocus job I had ever done...no way I could've done it with a single focus point. The second and third ones are easier but still hard because of split timing.
04-17-2018 04:52 PM
Quote: Above BIF capture is really great, please share the setting, it will further improve my skill.
