Search instead for
Please help!
uam225
New Contributor
I shot a friend's wedding last week with a rented 5D iv with a 24-70 2.8. After importing files to lightroom i noticed this effect on a lot of the pictures. They looked fine on the camera and when opened in lightroom first they appear fine but aftrer a few secs this appears. Does anyone know what's going on? Any chance of recovering/fixing the issue?2B2A0904.jpg
12 REPLIES 12
wq9nsc
Respected Contributor
Do you still have the card with the original files?  Save them and download Canon DPP software and see how they look in it; I suspect they will be fine.
I always shoot in RAW and use the excellent RAW converter in DPP to "process" the files before sending them to Adobe.
What camera have you used in the past to create files for lightroom?  Your computer (CPU, memory availability, graphics card, etc.) may be having an issue with the much larger files created by the 5D IV compared to some less capable DSLR models.
Rodger
EOS 1DX M3, 1DX M2, 1DX, 5DS R, 1D M2, EOS 650 (film), many lenses, XF400 video
cicopo
Esteemed Contributor
I don't use Lightroom but like most software you may not have an update which includes properly reading the files from the 5D4. Check which version you have & see if there's an update available. (this assumes you aren't using an on line version).
I believe this is going to be related to hardware.  Are you downloading straight from the camera, or are you using a card reader?
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~ImageClass MF644Cdw
hi shadowsports, i used a card reader
Between a bad sensor, bad software, or a bad memory card, something is wrong.  What version of Lightroom and ACR are you running?
What do the RAW images look like in Canon’s DPP?  What does a JPG look like when you create in the camera?
What brand and model of memory card(s) were you using?  Did you format it in the camera prior to first use?
hi Waddizzle, im using Lighroom Classic 8.3.1 and ACR 11.3
The pictures look the same in all softwares. Tried Canon DPP, photoshop... The JPG rendition on the camera looked fine, on lightroom they seem ok for a few moments while it loads and then goes like this.
The memory card was Lexar Pro 1066 256GB. I did format before shooting.
Thanks for taking the time to ask.
kvbarkley
Honored Contributor
It looks fine for a few moments because it is showing the embedded preview. It appears your RAW data is corrupted.
I do not know if you are describing a CF card, an SD card, or a micro-SD card.  Plus, there are variations on the performance of memory card.
From the 5D4 Instruction Manual.
RobertTheFat
Honored Contributor
I've used Lexar Professional cards for years and never had a problem. But at this stage of the game, I would avoid any 256GB card. Whenever you're pushing the envelope of size, speed, or whatever, you increase the probability of tripping over an unknown firmware bug or file system peculiarity. The alleged benefit isn't worth the risk.
Or as Alexander Pope put it three centuries ago:
"Be not the first by whom the new are tried
 Nor yet the last to lay the old aside."
Bob
