03-18-2020 06:38 PM
03-19-2020 09:27 AM
@SamuelGong wrote:
I'll explain the scenario here. I go out late at night to shoot star trails. The camera can't focus because it's too dark outside. If I put it on manual focus, the result is very blurred as the focus is not responsive.
If you are doing star trail or astro photography what you really want to do is focus on an "infinity" subject in the daytime using AF. Then switch to MF and tape the lens focus ring with gaffers tape so it can't move.
A less dependable option (only becasue you may not be able to find a subject) is at your photo location try and find a bright object like maybe a building in the distance. Focus, switch to manual and tape lens (or be careful not to touch focus ring).
03-18-2020 06:56 PM - edited 03-18-2020 06:56 PM
What lens are you using? Most should have an AF/MF switch. Switch it to MF.
For the issue when not being able to focus in low-light, what focus point are you using? The center point itself will often have the best capabilities to lock onto focus even in very low light (EV -3 or darker for some cameras).
I think you may be also able to use an on-camera flash just for the focus-assist capaiblity? Haven't tried that myself.
03-18-2020 06:59 PM
03-18-2020 07:01 PM - edited 03-18-2020 07:02 PM
The EF 24-105 f4 definitely has an AF/MF switch. Just switch it to MF to now be in manual focus mode.
Edit: Just re-read again your question... do you mean the ability to leave it on AF but then use manual focus override? If so, that lens has full-time manual focus override.
03-18-2020 07:02 PM
03-18-2020 07:04 PM
03-18-2020 07:06 PM
I'm not sure I follow the statement that focus isn't reponsive.
While I haven't ever captured a star trail, I'm going to assume you want to put the camera in manual and then focus to infinity?
03-19-2020 09:27 AM
03-18-2020 07:07 PM
03-19-2020 09:29 AM
