07-20-2021 11:22 PM
I have four SD cards, Sandisk of various stripes, 128 through 16G. Today when I went to the camera I got the "can't access card, format card or change card" message. No ERR, just that. I've done all the possible research and haven't found a solution yet. I can try buying a new card but why would that work? I've had the camera a few weeks and really fell in love with it Dang! Win 10 Home Pro 24G RAM, Gigabyte Mobo, i5 CPU. Help! There are older posts on this board but they haven't helped me.
Thanks
07-21-2021 08:15 AM - edited 07-21-2021 08:22 AM
Welcome to the forum.
Not clear from your post - does this happen with all four cards?
07-21-2021 08:21 AM
Is the card slot perhaps damaged? Are its contacts clean?
07-21-2021 10:27 AM
Also make sure the card(s) are not locked or write protected.
07-21-2021 11:06 AM
You have Windows so try to format the SD cards on your Windows machine. I am not sue a Mac will work but it might. If they format on your Windows computer the SD cards are probably OK.
About all you can do is check the interlock is not set to on, on the SD cards. Probably a good idea to reset the camera too. Menus, tools, clear all settings and clear all custom settings. Its pretty difficult to damage the SD pins in a 6D Mk II or any SD camera for that matter but it can be done.
BTW, a new SD card is always a good idea. Makes sure it isn't Dollar General/Walmart/Amazon cheapo house brand.
"I've had the camera a few weeks and really fell in love with it..."
Pretty easy to do  but it should be under Canon warranty so if it is a faulty camera they will fix it.
07-21-2021 12:52 PM
Thanks for your replies. I"m going quietly nuts. All four cards show this error. All Sandisk, and they have worked in this camera and in previous cameras. Right now I"m doing the fulllll and Very Slow format of a 64G Sandisk Extreme. This is going to take a while. I'm also going to buy a new SD card, name brand, asap. Somehow I think it's the cards and not the camera. Something happened on my computer. I recently installed Pshop 21 and both versions of Lightroom (plus Classic) and for no reason I suspect something in the software department fouled my cards. NO interlock. I only wish it were that simple.
07-21-2021 01:08 PM
07-21-2021 02:34 PM
Are the cards full size SD or micro SD with an adapter? You should only use the full size cards.
07-21-2021 02:46 PM
@artsdigiphoto wrote:
The default ffile format is exFAT, just clicked on device default. Not FAT32?
The camerfa manual says device incorporates exFAT technology.
07-21-2021 03:22 PM
I just talked to Canon service. I'll have to ship the camera for repair.
