12-28-2020 01:28 PM
New to portrait photography and having trouble getting crisp images in low light. Shooting on a Rebel T5i with the 18-55mm kit lens. AF and stabilier on. Is there something I'm missing or is it time for an upgrade to something with a better sensor or ISO?
f/5, 1/100, ISO-3200
12-28-2020 06:28 PM - edited 12-28-2020 06:31 PM
@ambaranowski wrote:
As for aperture, from what I've been reading, portraits need a wide aperture. I've been setting my camera at it's widest (f4) and then focusing on the eye closest. Am I learning wrong? Do I need a smaller aperture for two people like the shot above or smaller in general??
I'm working with a 3MB JPEG and a cropped section, but you got a decent portrait of the adult at f/5. Nose to ears is sharp enough not to be distracting.
But yes, the baby is not sharp and you would need greater depth of field to get both subjects sharp.
A portrait you would take of a person for that person would have different criteria than a photo you were taking for yourself as a creative art. A customer expects the image to be "real". They want it to be sharp.
12-29-2020 06:22 AM
@ambaranowski wrote:New to portrait photography and having trouble getting crisp images in low light. Shooting on a Rebel T5i with the 18-55mm kit lens. AF and stabilier on. Is there something I'm missing or is it time for an upgrade to something with a better sensor or ISO?
I found this article to be pretty helpful:
https://www.techradar.com/how-to/best-aperture-and-focal-length-for-portraits
Here's one example they give:
Steve Thomas
12-29-2020 10:26 AM
Here are some considerations. If you intend to go mirrorless don't buy any more ef or ef-s lenses. If you are into real estate photography don't buy a 50 mm prime. Could be one of the worse FL for real estate photos. BTW, you have 50mm already in your kit zoom lens. If you want or think you need 50mm just set it there.
DOF is probably not the problem shown in your example. At f5 and 37mm the DOF is almost 4 feet. DOF relies greatly on focal length. Even wide open apertures benefit in DOF when FL is decrease. DOF is also affected by distance from subject.
As to open aperture or small, it depends on your goal. Both are good and correct.
You do need more light for the conditions in your sample. You can add a flash but a flash brings along all its little quirks too. Your WB is off and if it was better that would make the shot better. A mirrorless camera in itself will not make a shot like that better. More light will. Another is post editing.
12-29-2020 10:31 AM
Nice shot!
01-05-2021 07:31 AM
01-05-2021 09:40 AM
There is enough light if you don't need a flash, and/or your shutter speed is fast enough with a relatively low ISO.
Now, you might also have an issue with mixed lighting throwing the white balance/flicker detection off.
01-05-2021 09:41 AM
"BTW, you have 50mm already in your kit zoom lens. If you want or think you need 50mm just set it there."
I do not understand the logic of this argument. There is a major difference between 50mm f/5.6, and 50mm f/2.8, or even wider. It is called 2 stops. When you need more light, then using a faster lens is much preferred over using a higher ISO.
01-05-2021 09:44 AM
So one more question and then I'll put this thread to bed: how much light is more light? This shot was taken indoors but the subjects were facing a wall with two windows about six feet from them. Not a sunny day, but still plenty of natural light. There were also four bright recessed lights above them, four in each of the adjoining rooms, and two windows behind them (15' or so away). What makes indoor photography "well lit"? Even my outdoor shots on cloudy days seem grainy. Does well lit have to be full sun?
Your metering system in the camera should tell you when your exposure is properly set for the available light.
However, indoor lighting can actually fool the camera into thinking there is more available light than there actually is. Indoor lighting tends to flicker faster than the eye can see. If the shutter fires at the wrong moment, then the photo will look underexposed, which sort of what your original photo looks like. Some cameras can detect flicker, and will fire the shutter only when indoor lighting is at its' brightest.
01-05-2021 10:29 AM
" "BTW, you have 50mm already in your kit zoom lens. If you want or think you need 50mm just set it there."
I do not understand the logic of this argument."
I'm not surprised. It gives you the opportunity to try being forced to stay on 50mm without spending any money. That's all, so you can see how limiting a prime can be. If you'er good with it you might want to buy the prime if not now you know.
01-05-2021 10:30 AM
"When you need more light, then using a faster lens is much preferred over using a higher ISO."
No, not necessarily. That may be your opinion but it is not true or a fact.
