Manual Focus on R50 - "Focus Mode" setting not displayed
jdege
I have a Canon EOS R50, and I'm trying to use it with a Tokina 400mm F8 Reflex MF lens.
The lens is manual focus only, and does not have an AF/MF switch.
If I mount the lens, and try to use it, the shutter does not trigger. I'm assuming that this is because the camera is set to AF, and it cannot AF.
So I've tried setting the camera to MF. The instructions I've seen online tell me that there the AF menu 1 should have a "Focus Mode" setting. That setting is not there.
I've reset the camera to factory settings, and it's still not there.
Without the setting I cannot switch to manual focus, and without manual focus I cannot use the lens.
Ideas?
p4pictures
Mentor
Mentor
You may need to tell the camera to take photos without a lens attached.
Go to the custom functions menu C.Fn-3 and then change the Release shutter w/o lens settings to On: Enabled.
Brian - Canon specialist trainer, author and photographer
https://www.p4pictures.com
I use British not American English, so my spellings may be a little different to yours
2 REPLIES 2
p4pictures
Mentor
Mentor
jdege
That was the problem.
Thanks.
