10-18-2021
09:08 PM
08:28 AM
I am a fairly experienced EOS user but am a bit perplexed. WIth an EOS R6 and RF 24-240 lens, on many photos I get lines around the edges (see example). I am not sure why these appear, but they do not seem strictly correlated with focal length or aperture. Any suggestions? TIA!
10-19-2021 01:33 AM - edited 10-19-2021 05:45 AM
You are using Adobe and its lens correction version 2. Use version 1.
Nothing wrong with the camera.
Possible to recreate by choosing the wrong scale in dt.
10-19-2021 06:51 AM
10-03-2024 03:57 PM
Hi, having the same issue, did you ever figure out what the problem was?
10-03-2024 04:01 PM
An Adobe lens correction issue. Just where are you seeing this?
10-04-2024 06:41 AM - edited 10-04-2024 06:47 AM
The problem in Lightroom is the profile. AutoScale is set to false when it should be true. The profiles are in lcp format and named after the lenses. Just open with a text editor and change yourself. Or use v2 instead of v3.
10-04-2024 08:06 AM
Pardon my ignorance. Where can you find the profile files?
10-04-2024 08:28 AM - edited 10-04-2024 08:32 AM
User/Adobe/Camera Raw or something like that. Or just use the search tool in your OS.
