02-12-2014 02:39 PM
Please help, I changed my iphone 5s and forgot the password connected to my Cannon 6D, possible to reset, I can't find any instruction from Manual. Thanks.
09-27-2017 06:27 PM
11-01-2017 01:41 PM
Thank you 🙂 It works for me 🙂
12-10-2017 07:16 PM
@dgtlfnk wrote:
FOUND IT!!
Select Wi-Fi function > And then on the ‘Connection’ screen, select Exit. Don’t just *exit* the screen by hitting menu. Actually select Exit on the touchscreen or highlight Exit with the directional buttons and press the *enter* button.
On ‘Exit wireless LAN function’ screen, select Ok.
Now press the ‘Info’ button to enter General settings. (Or make selection on screen.)
Now you can choose ‘Clear Wi-Fi settings’ , select Ok. Once you do that you can then create a new “camera Wi-Fi”, in which you can then be given the password during the creation process.
Whew! That was driving me nuts!
Let me know if that works for anyone else!
Thanks! That worked for me as well. This should NOT have to be this painful!!!
04-15-2018 08:26 PM
Taylor - so glad to see you also are so frustrated with this - can't get the 6D used body I just bought to work WiFi correctly either...Daniel
02-22-2021 04:27 AM
Thank you!!! You saved my mind today!
02-22-2021 09:48 AM
@ninakarlsson wrote:Thank you!!! You saved my mind today!
Glad to see this still being helpful!
03-30-2021 04:47 AM
04-21-2021 01:41 PM
I can FEEL that response, emanphoto. It's exactly how I felt when I figured it out finally. Lol! Glad you have it working again. ✌🏼😎
09-13-2021 11:08 AM
thanks SO much but mine asking for a password, is that the encryption number?
09-13-2021 09:00 PM - edited 09-13-2021 09:03 PM
If you followed the steps above, it gives you the password during the camera Wi-Fi creation process. You'll need to remember that number to use whenever you try to connect to the camera.
if you forget the password, start over and do the steps again.
I haven't used the new version of the app in a while. But this end of this Canon software is obviously still the same. 👍🏼
