11-24-2018 05:14 PM - edited 11-24-2018 05:15 PM
Hi everyone, so this problem has been going on for more than a year now. It started happening after my camera experienced some water damage. The camera is able to sense when flash is needed but each time, the flash pops up but the actual light itself does not go off. As I keep the button pressed down it just says "busy". Is this because of the water damage? How can I fix this problem?
Thank you!
11-24-2018 05:21 PM
Yep looks like the water did it and it is not a coincidence but have you done a full reset to defaults with your fingers crossed?
11-24-2018 05:24 PM
What model camera is it? There are a lot of people here smarter than I that might know of some obscure setting that could be causing your problem
11-24-2018 05:46 PM
Its a Canon EOS Rebel T6i and no I have not done a full reset!
11-25-2018 11:39 AM
It is possible for the flash tube to burn out. It has to be replaced by Canon which you should call at 1 (800) 652-2666.
However, they will not be happy when you tell them it got wet. Cameras and water don't react well together.
11-25-2018 12:59 PM
@jannatulahmed wrote:Its a Canon EOS Rebel T6i and no I have not done a full reset!
You are very fortunate that the water seems to have only damaged the strobe element, or its’ associated charging and control circuits. The camera can still take pictures, so it is good to go. The onboard strobe is pretty weak, and not very useful, anyway.
I suggest that you buy an external flash. It would be cheaper than a repair. Hopefully, the external flash shoe is still functional. If not, the external flash would still be useful should you decide to buy a new camera body.
