11-10-2016 09:36 AM
Can anyone confirm if the Sunpak PF30x works with the Canon EOS 750d? thanks
11-10-2016 09:41 AM
According to Sunpak website it is ETTL II compatible, so it should.
11-10-2016 09:56 AM
When I connect a Sunpak PF30x flashgun to my Canon EOS 750d I cannot get it to work, when I look at the setup it says inconpatable flash or its not switched on.. are there other settings I need to look at? thanks
11-10-2016 10:47 AM
@MarkP wrote:When I connect a Sunpak PF30x flashgun to my Canon EOS 750d I cannot get it to work, when I look at the setup it says inconpatable flash or its not switched on.. are there other settings I need to look at? thanks
Even if (as John's information indicates) the unit is ETTL II compatible, it doesn't necessarily mean that that's its default setting. Make sure that its mode is actually set to ETTL or ETTL II.
11-10-2016 11:01 AM
Thanks Bob and sorry I'm new to photography. When I go into Flash control the E-TTL 11 meter is set to Evaluate, the only other setting is Average.
11-10-2016 11:24 AM
Is this on the flash or the camera?
Do the pins on the foot of the flash match the connections on the camera? For Ettl-II it needs *all* of them, not just the big center one.
11-10-2016 12:40 PM
Do you get that error message when Sunoak is installed on camera, lock wheel tightened and Sunpak switched on?
11-10-2016 12:54 PM
This site states it's not compatible with later model cameras. Must be more than just ETTL II that needs to be complied with.
11-10-2016 01:26 PM
11-11-2016 01:35 AM
Just because it is ETTL II compatible is no indication it is Canon compatible. It only means it will expose using the ETTL II standards.
