EOS Rebel T7: software needed for transferring photos
tjjjc2
Hi, do I need to download and install any software to get pictures on the PC?
I have windows 7 and Canon Rebel T7
2 ACCEPTED SOLUTIONS
Tronhard
VIP
VIP
Hi and welcome.
No, you can remove the SD card from the camera and use an SD card reader attached to the computer to access the DCIM folder on the card and copy the images to your hard disc via the file manager.
cheers, TREVOR
stevet1
tjjjc2,
You don't absolutely need software. You can use the method Trevor suggested by taking them from the card.
If you choose to use software, Canon offers a free program called EOS Utility that handles transfers. You can get a copy from Canon's Support Page here:
https://www.usa.canon.com/support/eos-utilities?_gl=1*vrvuhe*_ga*ODgyNjgwMTgzLjE3MjY2MjIwMzE.*_ga_RS...
You just tell it what kind of camera you have and the operating system of your computer.
You can use a USB Cable to connect your camera to your computer. Your manual should have a recommendation for that Cable.
You open up the software, turn on your camera, check off the pictures you want, and hit download. The software is nice enough to put them in folders organized by shooting date.
I use that method all the time.
Steve Thomas
7 REPLIES 7
Tronhard
VIP
VIP
Hi and welcome.
cheers, TREVOR
tjjjc2
Hi thanks, right now I have tried 8 times to read the SD card on different USB ports. Next I'll reboot and try.
Is your SD card a Micro-SD with an adapter?
cheers, TREVOR
stevet1
tjjjc2,
Steve Thomas
tjjjc2
Thanks so much for your advise and help.
Tintype_18
Does your computer have a card slot in the side? I can insert the card and download photos w/o a cable or reader.
John
tjjjc2
Hi, no slot
