EOS 6D Mark II Doesn't Want to Turn On
shasta
My 6D has not been wanting to turn on. I replace the battery and card several times and it will finally turn on after a few times. Has anyone else had this issue?
12 REPLIES 12
I have the LP-E6 series battery and the camera turned on without the lens or SD card in it. Then I turned it off and back on again and it would not power up. This is the issue I have been having.
Tronhard
VIP
VIP
I think it is time to consider calling Canon Tech Support at 1-800-OK-CANON.  They can help you further and if necessary set up the process to have the camera serviced.
cheers, TREVOR
In addition to the great advice above, and after removing card, lens, etc.  Please perform a factory reset on the camera.  Do both the camera and custom (C) menus reset.  Then retest.
We also need to ask if the camera's power switch is loose or faulty?..  and have you upgraded the camera's firmware by chance?
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
Avatar
