05-12-2024 11:59 PM
Usually, I can see the photo or scene on my LCD before I take it, but now all I see is a black screen. However, whenever I hit the shutter button to focus, it shows me the image before I take it, but then goes back to black. I'm so confused because I'm in a very well-lit room and have my ISO at 200 and shutter speed at 1/125th. I've never had a problem like this in my room before. I'm confused because I never changed my settings on the camera, and my camera was perfectly working yesterday since I took photos all evening yesterday. Does anyone have a fix for this, or is my camera broken?
05-13-2024 02:51 AM
Indoors with the exposure manually set to 1/125 f/5.6 and ISO 200 I would expect an almost black frame. Your camera is simulating the exposure and showing you the black result you'll get from the settings you have set. You can see EXP SIM on the right side of the display. You can also see that there is a small triangle under the exposure scale and it is fully to the left side indicating more than 3-stops underexposure.
There are two solutions;
You might not have seen this kind of problem before if you were using another mode such as Tv, Av, P and or where using auto ISO, since in those situations the camera can make some setting adjustment to give a correct exposure.
05-13-2024 01:06 AM - edited 05-13-2024 01:13 AM
Hi Benjamin and welcome to the forum:
Have you tried prodding the INFO button a couple of times. If you inadvertently pressed it, you may have put it in a mode to not display the shooting in live view. Failing that, have a look at the section in your manual for Shooting Information Display, on P312. If you don't have it Google "EOS R8 Advanced User Guide".
As an aside, while it might be fashionable to compose and shoot by looking at the rear LCD, for still photography it is a much more stable platform to bring the camera up to your eye and thus get 3 points of contact.
05-16-2024 11:24 PM
I was just showing you the issue, I don’t usually hold my camera that way, the only reason I did that was to capture photos of my camera with my other hand. Thanks for the reply though.
05-13-2024 02:51 AM
05-16-2024 11:22 PM
Thanks for being so helpful. Turning off the Display Simulation fixed it.
