10-05-2024 02:37 AM - last edited on 10-05-2024 08:16 AM by Danny
Hi my name is Roddy I have a Canon EOS 4000d and I want to buy a lens for it I'm looking at canon ef 50mm f/1.8 STM lens I don't know if it'll fit do I need an adapter if so which one do I get ?
10-05-2024 03:40 AM
Hi Roddy,
that camera has an EF-S lens mount, and so will take any EF or EF-S lens; no adapter is needed. See your camera's specs here: https://www.canon.co.uk/cameras/eos-4000d/specifications/
Note that the camera has an APS-C ("crop") sensor, so EF-S lenses will work fine; EF lenses may be bigger than you need, but will also work fine. If you buy EF lenses (as opposed to EF-S), and later upgrade to a full-frame camera, those EF lenses will transfer across no problem. EF-S lenses will not.
The EOS 4000d will not take any RF, RF-S, or EF-M lens, with or without an adapter.
If you want to know more about lens compatiblilty, I wrote a guide to that: https://moonblink.info/MudLake/gear/lenses
10-05-2024 02:44 AM
Canon EF 50mm f/1.8 STM lens
Canon ef-s 24mm f/2.8 STM lens
Well these lens work on a Canon EOS 4000d?
10-05-2024 04:20 AM - edited 10-07-2024 12:27 AM
@Roddy wrote:Canon EF 50mm f/1.8 STM lens
Hello,
Yes, both the Canon EF 50mm f/1.8 STM and the Canon EF-S 24mm f/2.8 STM lenses are compatible with the Canon EOS 4000D. FloridaBlue
Best Regards,
James
10-05-2024 01:44 PM
Roddy,
Both lenses will work like a charm!
Good luck!
LZ
