10-02-2023
07:04 PM
01:19 PM
SamanthaW
Hello! I am using a 90D with a video capture card to stream. I am hoping to use the Servo AF feature, but to lose the displayed box around my face. I recognize that switching to manual focus will remove this box (which is my stopgap solution), and that switching to other forms of autofocus will replace them with a different box. The lens I am using is the kit lens from a Canon T3i.
I rechecked the manual having previously read it, but unfortunately, it seems it did not include the necessary information.
Here is a 30 second clip of the issue. Thanks for your help!
Clip: https://clips.twitch.tv/ProductiveSassyAyeayeChocolateRain-sOOQzSTHTD-CvSkW
10-02-2023 07:40 PM
Replying to myself here for future users-- though this was selected in the attached clip, unselecting the option, reselecting it, and power cycling the camera seems to have worked! Thanks so much for your help regardless!
10-02-2023 07:17 PM
According to the EOS Webcam Utility page, the 90D has clean HDMI output. I suggest that you download the Instruction Manual to find the settings.
https://www.usa.canon.com/support/p/eos-90d
Not all lenses are capable Movie Servo AF, especially older ones initially released prior to 2009.
10-02-2023 07:21 PM
Go to the menus an make your choice for HDMI output.
10-02-2023 07:31 PM
Thanks very much for your reply! I have taken this step-- you can see the clean output in the posted clip.
10-02-2023 07:33 PM
The autofocus does seem to be functional, however, the facial detection box remains.
10-02-2023 07:40 PM
02-11-2024 01:51 AM
Hi Phil, I'm having the same issue, trying to use my Cannon 90D as my webcam. I've been able to remove everything except for the focus box around my face.
I tried to understand the above thread but can't figure it out. Even when i change my camera setting to M - its still shows which I know you mentioned as a solution.
Any advice would be greatly appreciated
