03-28-2019 09:36 PM
I had the perfect system for myself when I had a 5D Mark II. I tethered to EOS Utility; downloading just a JPG. Saved it to a certain folder. That folder in turn was a watched folder in Lightroom automatically bringing the files into Lightroom. A little slow but worked for me without spending any extra money.
Since I've purchased my 5D Mark IV the tethering is not working. It will work for a few shots and then the Camera shows "BUSY" and will not transfer files to the computer. No length of wait time causes it to be "unbusy". I have updated the EOS Utility software and I am using the cable that came with the camera.
Please advise.
Thanks,
Pamela
02-15-2020 10:21 AM - edited 02-15-2020 10:23 AM
I was not able to get it to work either.
I solved my problem by starting to use Lightroom. I never wanted to use it before because it would only download the raw file which was too slow. But I was able to find someone online who explained how to get just the JPEG to download with my 5D Mark IV. Sorry but this will only work if you have a camera that has two card slots and Lightroom.
On the menu with wrench icon;page 1, select "Record func+card/folder sel"
Set record func to "Rec to multiple" This will record the same image on both cards.
Then (this is most important) set "Record/play" to card 2
Then go to the menu with Camera icon;page 1
For "Image quality" set card 1 to Raw and card 2 to JPEG med.
Then go to lightroom and set up for tethered shooting. It will download images from the card that you set "Record/play" to. This should be card 2 which is recording the medium size JPEG's.
This is probably still slower than some of the expensive set ups for tethering. But it works without buying any extra equipment or software. My clients can see their image on my computer. And I have the raw files on my camera.
hope this helps someone.
03-28-2019 11:39 PM
Hello pcather,
We are sorry this is the case. Do you mind letting the community know what version of EOS Utility that you are using?
03-29-2019 08:22 AM
03-29-2019 09:50 PM
pcather,
We recommend a complete un-installation of the Canon software and then re-install from the web site.
If possible, we also recommend attempting the installation on another machine to see if the issue persists.
03-29-2019 10:41 PM
02-15-2020 07:22 AM
I have the same issue.
Tryed on two different computers. Newest EOS Utility.
Please help! I can't do tethered shootings in my studio. 😞
BR!
02-15-2020 02:05 PM - edited 02-15-2020 02:15 PM
You [should] be using Canon's DPP software for tethered shorting, not the EOS Utility.
[EDIT]
The EOS Utility is intended to remotely control the camera, and store the images in the camera. The EOS Utility 3 does not offer an option to store images to a computer folder like the EOS Utility 2 did.
DPP4 has taken over the roll of tethered shooting and saving images to computer folders. It has the better front end for it.
02-15-2020 07:25 PM
@Waddizzle wrote:You [should] be using Canon's DPP software for tethered shorting, not the EOS Utility.
[EDIT]
From EOS Utility 3.12 manual:
02-15-2020 08:10 PM
John,
That setting is for downloading images from the memory card in the camera, not for tethering.
This screen shot is from DPP4. This is where you can set the destination folder for photos taken using the EOS Utility 3.
