40D to 90D
srd-software
Hi, I have a 40D and have hardly used it all these years since it does not take video. It looks like a 90D would be a good replacement but I had a few questions.
  • Will my current lens (Canon 18-55 AF Stabilzer - got it with the camera years ago) still fit/work?
  • Will my accessories fit? Battery, USB cable, shutter release cable
  • The 90D now uses an SD card, and has no provision for a CF card correct?
  • Any ideas on trade-in value I might expect for the 40D towards a 90?
Any help appreciated.
amfoto1
Let's take your questions one at a time....
LENS: Your EF-S 18-55mm IS lens will work fine. If it's the older one, you might want to spend a little extra and get one of the newer lenses. The EF-S 18-55mm IS "STM" is faster and quieter focusing, and has improved image quality, compared to the "micro motor" versions (which don't have "STM" imprinted on them).
Bryan Carnathan has comprehensive reviews and thorough comparisons of the various EF-S 18-55mm versions on his web site. Start here with the latest EF-S 18-55mm lens. There are links to the earlier ones, so you can determine which you have and how it differs from the latest ones.
Honestly, though, the 90D is such a nice and highly capable camera you might consider getting a more versatile lens to use with it. 90D is often offered "in kit" with the EF-S 18-135mm IS USM  This is a more "mid-grade" build quality lens with higher performance autofocus that complements the camera's much more advanced AF system (especially compared to the older 18-55mm micro motor lenses).
90D body only (no lens) sells for $1199.
90D with latest EF-S 18-55mm lens sells for $1349.
90D with EF-S 18-135mm IS USM sells for $1599.
The EF-S 18-55mm IS STM lens sells separately for $249, so there's really no discount buying that basic kit lens with the camera, but it would be a relatively inexpensive upgrade from an older EF-S 18-55mm.
The EF-S 18-135mm IS USM sells separately for $599... so when it's bought in kit with the 90D, you are getting a $200 discount.
Other even more premium, general purpose "walk-around" zooms are the Canon EF-S 15-85mm IS USM (wider angle, $799) and EF-S 17-55mm f/2.8 IS USM ("faster" f/2.8 lens for lower light conditions, currently on sale for $729).
ACCESSORIES:
- BATTERY... no. The 40D uses an older BP511A battery, which will not fit or work in 90D. The newer cameras use LP-E6N, but get a lot better battery life with them, as well as provide more info. One of those will be included with the 90D when you purchase it, as well as the new charger it requires. If you want extra batteries, there are cheaper third party "clones", but be careful. Most cannot safely be charged in the Canon charger. They require a special charger or their own and do not give the same information in the cameras. One exception is the Watson #B-1544-2 (not the #B-1544). That can be charged in the Canon charger and has full communication with the camera, same as the Canon OEM batteries.
- USB... A new USB cable will be provided with the 90D. Your old one might work, too. Those cables are pretty standard.
- SHUTTER RELEASE:
- - - Wired... No, your 40D uses the RS-80N3 or TS-80N3. The 90D (80D, 70D, 60D) uses the less expensive, smaller RS-60E3. There are also various third party remote swithces and timer/controllers (though I think the 90D has built in time lapse ability, so may not need that).
- - - Wireless... Probably... the little Canon RC-6 can be used with the 90D and has been around for many years, might be what you have for use with 40D. There also is the newer BR-E1 which connects via Bluetooth. Which reminds me, you also can connect via a smartphone and even use it's screen for remote shooting.
- SHOULDER STRAP... will also be included with the camera.
- MANUAL Not sure if there is a printed manual included... Many Canon come without one now, or only come with a somewhat abbreviate manual (about 150 pages). There are complete, free, downloadble PDFs available from the Canon USA website. Those can be loaded onto a smart phone or tablet, for convenience in the field.
- MEMORY CARD... Sorry, but no.  Can't use CF cards. 90D has a single memory card slot and only accepts SD memory cards. Fortunately, those aren't expensive. (I just bought two 32GB SD cards for $32.)
Your best bet to "cash out" your 40D would be to sell it yourself either locally or via everyone's favorite online auction site. You will get more money for it that way, than you would tradiing it in to a retailer. They will only give you "wholesale" value, probalby about 2/3 the current typical selling price.
If your 40D has hardly been used (be prepared to prove it by getting a current "shutter count" from it) and it is bundled with extra items such as lens, spare batteries, charger, manual, strap, memory cards, you would probably get more than the average selling price. You can see what they sell for on that auction site, just search for "Canon 40D" and then click on "sold items". Be prepared, you might cry!
Hope this helps!
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
19 REPLIES 19
kvbarkley
VIP
VIP
I can't answer them all, but:
-The lens will fit.
- All other accesories but the battery should fit. The USB cable might not work if they switched to the cell-phone like connector, but that is hardly a showstopper.
- It only allows one SD card.
Here is a good review:
https://www.kenrockwell.com/canon/90d.htm
ebiggs1
The fact any or all your current accessories with fit isn't the issue.  The bigger question is why?  Everything is better now then it was when the 40D was new.  That was over 10 years ago.  Buy the 90D kit and you wil be better off.
EOS 1DX and many lenses.
srd-software
Thanks for the input. I suppose I could go with a new lens too, I'll look into that. I've never been real happy with the sharpness of most of my images. That lens might be part of the problem.
The 1Ds have fixed screens so they would not work for me.
Ernie was not recommending the 1D, he is just bragging about what he has. 8^)
Anyway, you might look at the EF-S 17-55, by most accounts one of Canon's best EF-S lenses.
I like the EF-S 18-135 because of its decent quality and longer reach.
"Buy the 90D kit and you wil be better off."
If you buy the kit, you get a new and current lens.
"Ernie was not recommending the 1D, he is just bragging about what he has."
It is common to have a "signature" at the bottom of your post.  It is also common and most folks like to know what a person is shooting or using.  This is my "sig"...EOS 1DX and 1D Mk IV and several lenses! It is not a recommendation to anyone else.
However it is very good! Smiley Happy
And sometimes the signature just states the poster's geographical area. You might be surprised at how many geographical areas are represented in this forum.
If you decide that you want a signature, click on "My Settings" to get started.
Bob
amfoto1
ACCESSORIES:
- SHUTTER RELEASE:
Hope this helps!
Alan Myers
FLICKR & ZENFOLIO
amfoto1,
Thanks for all the info. It helped a lot!
  • Lens: My lens is marked STM so I'll keep it for use on the next camera. This was the main thing helping me to decide what to do with the 40d and what to get next.
  • Memory card: I never liked the CF cards (pin-and-hole connection is fragile), so changing to something using regular SD cards is a plus to me (other stuff I have uses them too). I'll dump the CF cards I have with the body since nothing else I have uses that card.
  • Batteries, shutter release, strap etc.: No problem jettisoning those with the body. Nothing else I have uses them.
  • Shutter Count: I can't get that now. After 3 (that's right, THREE) uses of the USB, the port stopped working. Unbelievable, terrible quality. The 40d is worth so little now it's not worth fixing.Since the USB pooped out, the effective value of my 40d body is about $0. So there won't be any "cashing out." They only fetch about $100 on ebay now at best anyway and it would cost at least that much to fix it. I am very disappointed with the 40d and look forward to giving it away to a charity.
The 40d was SO bad that I thought about moving to nikon but since my current lens still works and I can use it on the next body, I'll try one more canon. But this will be the last one. If I continue to get mediocre 40d-type photos and have any more build/quality problems, the whole thing will go. I loved my old 35mm FT (not FTb, FT). That one (with a Vivitar wide angle lens) took the best photos of any camera I've ever had. It finally started having shutter problems so I got an AE-1 black body. At any rate, my experience with those were why I stayed with canon.
I won't bother with a 90d as I don't want to spend that much money on a camera that will be worth $100 in a few years. I'm going with an older model that can do video and has already depreciated some (less to lose if this next one is as bad as the 40). I'm looking at a 70d now. Maybe an 80d but the 70d looks like it will do what I want it to do as far as video is concerned.
I really do appreciate your help. I'm just so disappointed and disgusted with the 40 at this point that I had to rant a little.
